Sloppy steering / new rack
I've got a new steering rack and my steering and/or general front end handling is getting worse now with intermittent steering wheel vibration on highway and heavy vibration while braking - is there anything in particular I should be looking for? I'm going to jack up the car and crawl under there this weekend while its sunny and warm out.
Complete front-end brake job & new steering rack within the last 12 months.
I am planning on ordering a complete poly bush kit for the front end anyway to match my new rear racing spec bushings/cage mounts but it wasn't a priority until this recent issue.
Some things to check:
Good luck.
- Brake rotors warp very quickly. I have had recent experience of a friend's car with brand new ones, fitted to less than 1 thou runout at the rim, warping and juddering after 2000 miles. Check them for runout.
- Check the pads are seated properly and wearing evenly
- Check the wheel bearings are adjusted up properly
- Balljoints can go home very quickly too. Carefully check top and bottom and the ones on the steering arm/rack ends. Check for tightness and the actual ball not having play in its socket
- Check toe setting and wheel balance
- Check also that the camber shins are in the top wishbone/balljoint fixings. If a garage did this work they might have lost them. If any have been left out, put one thick and one thinner one each side of the balljoint as a starting place. Even one of the four missing can produce steering oddities as I recently experienced myself.
Good luck.
The following 2 users liked this post by Greg in France:
orangeblossom (02-10-2018),
Rivguy (02-10-2018)
2000ViperGTS
01-02-2014 02:56 PM
chupacabra
07-16-2010 04:53 AM
