Slowly Slowly V8 XJS
The following 4 users liked this post by melhookv12:
With the six speed I take it this car will see some, if any street use. Maybe it's already be mentioned (I missed it) about your fuel delivery system, tank etc., the suspension, IRS/diff mods & ratio ? BTW your workmanship is up & beyond ! IMO this engine is the way to go if you want to "make 500 HP" and WAY beyond for that matter.
89 Jacobra (12-10-2017)
Very Nice, Man after my own heart. Is that a Supercharged 4.6? out of a Shelby? You are going the new school way with yours, I'm going old school. Ford 460 with about 650hp The one thing that's been brought to my attention about our XJS's, is the fact the rear end cage assembly, is just kinda sitting in place, LOL Seeing that yours appears to have been a race car at some point. I wonder how it has been addressed. I like the pics of the engine bay without the engine as I'm have some clearence issue's with the headers and wondered how far I could go cutting to make them fit. Excellent Job I will definitely watch your build with great interest. Cool Choice of Motors.
Jack
Jack
The following 2 users liked this post by ptjs1:
89 Jacobra (12-12-2017),
Timeisrelative (10-05-2020)
no valley pipes as such as not using a heater. see the blue silicon hose that runs under the charger to fill the block.
Jack
Jack
non standard jaguar rear suspension. fabricated lower wishbone bushes and fully adjustable for camber and toe.
ref clearance issues. bulkhead completely modified as the v12 sat further back. inner wings have been cut and made wider to accommodate the wider v8.
The following 2 users liked this post by melhookv12:
it's running outboard vented set up from later xjs. vented diff with cooler and pump.
Greg in France (12-12-2017)
Jack, I also thought the engine was a US crate. My experience with the stock IRS & diff is the four rubber cage mounts pulling apart, I replaced with OEM mounts three times!! My stock diff is a Dana 44. Under normal use both should be fine, but the mounts still deteriorate & will break over time. Poly & solid mounts are whole other subject. Ron Brothers did a nice job to control wheel hop & diff mods
Greg in France (12-12-2017),
ronbros (12-11-2017),
Jack
Wow Cool Pics, and lots of them, Thanks for the Update I;m still paying attention. LOL!
I've made some head way on mine, and My firewall looks very nearly the same as yours. I'm using metal about twice as thick as Jaguar did, and I'm overlapping in most areas, and using plug welds over larger flat areas. So I'm doubling things in several places for added strength. and rigidity. It isn't pretty yet, but I'm building a Hot Rod First. Then we'll set out to make it pretty.
Good Luck with it.
Jack
Good Luck with it.
Jack
Ok Mel, and ALL, I have to ask,,,
I have access to a 2004 supercharged 4.2 engine from an xkr... Would this work? Somehow, someway?
Without all the other AMAZING modifications, of course.
You guys a bleeeeping amazing with the things you do!
Deep bow, maybe I'll get there someday.
Me and my girl are looking at a house in the country with a 3 car garage AND a barn... Been looking at sail boats, 33footers, that go for under 4000$ sometimes. Best.Laid.Plans, lolololololololol 🤣
