so has anyone actually made 500bhp from a v12 pre.he
#201
Just a few words on bore sizes:-
90 std works fine, no known problems
91 bores std works fine, no known problems (std + permitted oversize for racing)
92 works well used in a couple of XJS race units and in Group C and GTP with 75 or 78 cranks. Special gaskets Group A , coopers rings Group C and GTP.
93 / 93.5 possible and used by Ron Betty on occasions, too thin and prone to crack if std liners used.
94 Group C , block needs boring and std style slip fit coopers rings used. Block boring required.
95 GTP coopers rings used with ring exposed to the bore which makes me twitch but no problems reported. Block boring required.
96 Rob Beere, early press fit custom liners crack around at the bedding seat, pain in the butt as total strip necessary to rectify. Later 96 with 'off the shelf' liners + std slip in fit work much better, Special gasket needed but works well. Block boring required.
98 / 100 needs offset block boring and you are on your own for liners and gaskets.
Armed with this info go for 90 92 or 96 all the rest will cost you even more money and may haunt you in nightmares.
#202
#204
Received 1,236 Likes
once you go past experince and use , nothing,, just can blow up,thats all!
building engines that go beyond recommended levels,really relates to available money!
mike i doubt xj6 pistons would work, if they did we would have known already about it
what to use for any bore piston? (except stock) should be a custom designed piece.
#206
The question should really be why go 94 when 96 is easier and cheaper, not to mention the disproportionate increase in power it gives.
#208
The problem with the 96 pistons with the shorter stroke is usually the extra weight. This is only a problem in high revving race engines. All these super dooper piston makers usually only have a few std piston forgings which they machine up dependent of whats needed. The Beere pistons (cosworth) at 96 were machined on the top for different strokes and comp ratios, the shorter stokes ie under 84, had extra meat on the top to give the extra comp ratio. Thats 4.75mm more on a 74.5 compared to and 84, thats a reasonable amount of weight. Reciprocating weight at that. But most aren't going to want 8K before changing gear!
#209
#210
Soo what would be the best reliable combination (Jaguar and reliable in one sentence?!?) For me its all on reliablility it is essential . Soo what would be the best combination? Thicker liners a small bump in bore size and magneiseum pistons? Billet Aluminum rods? Stock bore and stroke is 91.5mm and 75mm?
#211
Just in case it is of interest to anyone, on UK Ebay there are a number of unmachined blank 84mm forged crankshafts for sale, originally made for TWR:
Jaguar -TWR / Jaguar Sport V12 84mm Blank crank forging | eBay
Greg
Greg
#212
greg they been on ebay for more than 2-3yrs, the JF site went over the cost of machining ,lightening, shaping counter weights, drilling oil passages, shot peening , and nitriding the bearing journals for hardness,and finally balancing!
cost more than a shaft all done and finished!
just looked at pix of it, it isnt even drilled for flywheel or harmonic balancer, no rear seal surface, no nothing, cost would be outragous.
and the shop guy would have to WELL experienced!
#213
88 you gotta get a Jag V12 engine manual, stock bore is 90MM, and stroke is 70mm, for 5,3sL engines.
6L is 90+74.5MM stroke changes involved crank and pistons, rods the same!
best way for cost effectivness,,is get a factory 6.0L engine and mod it for a set of turbos, and tune it carefully!
#215
ron, 6l is 78 x 90.
74.5 is the stroke I stroked mine too.
but ron, if you get a 6l, you're going to need to drop compression to use turbos. so there is custom pistons, and rings. then you'll need.two good turbos, and working at a shop that builds 1000+ hp evos on the reg, a good turbo will cost you atleast 1600 a piece, times two, and then there is the fabrication of the turbo manifolds, which is gonna take some time(money) and then the intercooler setup which will restrict the airflow to the radiator, and intercoolers are not cheap.
THEN you need engine management, (which.I just purchased) and that won't be cheap, the electromotive tec3 6/12 I bought was around 3000$ new.
#216
#217
Thank you calvin , I haved used magnesium pistons for a bit over 4 years now on various projects never hsd an issue .we use them on racing mowers they take the abuse just fine with extreme heat and a slosh system so they're sometimes oil starved .we had one guy run a complete race at the end of the season with zero oil in the engine he came in second. Never knew until it was taken apart in the trailer what had occured. But I do agree I need a shop manual!!
#218
Greg
Greg
BTW the Jaguar factory 6.0L crank is 78.5mm, this can be stroked to 83mm without welding
#219
slight off topic; google 1320video, go to texas streets!
500hp cars are not even pictured, but a couple of fast as#sed EVOS are. turbos are bigger than the engines?
these texas guys,houston area, say they have the fastest STREET cars in the world, a friend of mine says i know some of them! YIKES. last time one of them gave me a ride,scared the living crap out of me, 130mph on a local street austin tx.
shows what unlimited money can do!
just something to show that ALL fast cars are forced induction. 200++mph cars are common.
check it out!
and Hennessy motorsports are just down the road! imagine that!!!!
check it out!
