so has anyone actually made 500bhp from a v12 pre.he
Old 01-13-2014, 06:14 AM
xjr5006's Avatar
One picture says a thousand words
Attached Thumbnails so has anyone actually made 500bhp from a v12 pre.he-xjr5006-137318-albums-garage-miami-gp-winner-7332-picture-screenhunter-59-jan-11-23-29-22686.jpg
ronbros (01-14-2014)
  #302
Old 01-13-2014, 06:29 AM
xjr5006's Avatar
xjr5B
XJR6
XJR7
  #303
Old 01-13-2014, 06:04 PM
calvindoesntknow's Avatar
And what is in those pictures is worth thousands of dollars. But that would be so awesome to have
  #304
Old 01-14-2014, 01:26 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
great setup! i wouldnt care how it run,
just lift the hood and show that BABY off, it would be the talk of the show! OH<YEAH.
  #305
Old 01-14-2014, 01:30 PM
ronbros's Avatar
thats right up there with looking at beautiful women!!!!
  #306
Old 01-15-2014, 12:14 AM
88-xjsv12's Avatar
Love it ! Thats about what I drew up. Attempt too upload pictures or rendering ls of my idea tomorrow.
  #307
Old 01-15-2014, 12:25 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
They would work, could be in a box sealed to underside of the bonnet and use Lister XJS style intake scoops
Attached Thumbnails so has anyone actually made 500bhp from a v12 pre.he-lister-jaguar-xjs-700-bhp.jpg
  #308
Old 01-15-2014, 07:34 AM
xjr5006's Avatar
my choice for something that runs on the road would be something like the AJ6 engineering system but in an aluminium casting. The crossover system looks wonderful but I wonder how well it works, its too low IMHO and the compromise of where and how the injectors and their fuel pipes are located with the necessity of fitting it all with clearance under the hood is problematical.
Injectors in a similar location to standard would allow a better curve, longer runners and higher throttle bodies with bellmouths easily clearing the cam covers and the hood, just my 2p worth. So I think the crossover system shown is a beautiful looking fail.
  #309
Old 01-16-2014, 04:35 AM
88-xjsv12's Avatar
Jaguar V12 Intake Manifold Dual Quad | eBaySurfing around the web today look what I found
  #310
Old 01-16-2014, 04:38 AM
88-xjsv12's Avatar
Any idea where too get ahold of the lister kits?
  #311
Old 01-16-2014, 09:53 AM
ronbros's Avatar
those air scoops are called NACA ducts, Summit racing sells many sizes.
good for getting air in without setting up surface turbulence,and drag.
fast aircraft stuff. old tech 1950s.
  #312
Old 01-16-2014, 10:02 AM
ronbros's Avatar
i mentioned that the AJ6 inlet manifold system is about the best compromise for an XJS under hood.
i dont think anyone is gonna come up with anything better, except a forced induction setup, and i do know that the simplest would be 2 remote mount turbos and a good standalone ECM, and there is enough room under a lowered XJS to do it!
and i dont do any off road driving, not my style!! lol.
Attached Thumbnails so has anyone actually made 500bhp from a v12 pre.he-r1-07368-013a.jpg
  #313
Old 02-10-2014, 01:47 AM
88-xjsv12's Avatar
Been away for awhile I couldnt get my original drawings up so i made a quick sketch of the simple ones . Sorry if they're not sized right I'm no artist
Attached Thumbnails so has anyone actually made 500bhp from a v12 pre.he-20140210_022945.jpg   so has anyone actually made 500bhp from a v12 pre.he-20140210_022957.jpg   so has anyone actually made 500bhp from a v12 pre.he-20140210_023012.jpg   so has anyone actually made 500bhp from a v12 pre.he-20140210_023018.jpg   so has anyone actually made 500bhp from a v12 pre.he-20140210_023650.jpg
so has anyone actually made 500bhp from a v12 pre.he-20140210_023654.jpg   so has anyone actually made 500bhp from a v12 pre.he-20140210_023026.jpg   so has anyone actually made 500bhp from a v12 pre.he-20140210_023700.jpg   so has anyone actually made 500bhp from a v12 pre.he-img_20140210_011657.jpg
  #314
Old 02-10-2014, 01:51 AM
88-xjsv12's Avatar
I would put oversized throttle bodys on it or three stock ones inline if your on a budget. I figure two 91 mm throttle bodys? Not positive of the stock size but I believe an increase of 25% in size would be key.
  #315
Old 02-10-2014, 07:00 AM
xjr5006's Avatar
I wonder if we are totally missing the point here; the std set up is the best production compromise for a road car. Easy starting smooth low tickover, instant pickup and more than adequate power delivery with as good economy as could be achieved at the time.Also remember the ever tightening emissions issues.
It is a total package.
Yes you can improve the (older) standard set up with modern injection/ electronics.
You want more power then be prepared to make make sacrifices in other areas. More power requires more fuel and more air, it needs to be able to get in and get out, of course it will cost more to do this than a 4, 6 or V8 because you have more of everything in a v12. you are wasting your time if you think that bigger throttles or larger inlets will do much without the matching larger head ports and valves, maybe with a change of cams and a different map.
You need a total package again, if its a bit more you need a bit more in all areas to maximise things. If you require a considerable increase then be prepared to make major changes in all areas, fairly obvious but often there is little difference in cost between going 1/2 way to going the whole hog, If you have to buy new pistons and liners then the cost has little to do with the size; it has to do with what is available. In Europe its 96 mm bore off the self. Cheapest crank may well be an offset ground unit starting at either 70 or 78mm. Rods will therefore be Chevy based most likely at 6" and everything follows on from there.
Might be different in the USA or Australia. What I am certain of is that just the changing of an inlet set up will be a waste of time and money, bringing disappointing results. You need a package.
  #316
Old 02-10-2014, 11:56 AM
ronbros's Avatar
5006, totally agree(a package for performance).
here in the states, for a lowly GM chevy V8, they sell a recomended Package,
it includes a set of Hi-performance cylinder heads, a custom inlet manifold, and a camshaft kit, that includes a cam that is correct for the head and manifolds, a set of lifters(cam followers), and a set of valve springs.
now they will sell any one of the components seperatly, but if you want good results, it is a complete package, and highly recommended!
  #317
Old 02-10-2014, 12:09 PM
ronbros's Avatar
and the old girl aint dead yet!
yesterday went to a car show with her, over 500 kool cars, i was directed to the Exotic car area(nice Ferrari's,porsche, audi R8 types, Lambo's, RR conv. Bentley's,Aston Martins, and more), parked me between a Viper and a Tesla roadster.
well turned out many viewers for my Jag, all kinds of braggin rights, mine you, you know this mod that trans,etc. but mostly about the standalone system, some couldnt believe ive had it 20yrs.
weather perfect mid 70s sunny, car run like a raped ape out on the hiway!
those pesky old Corvettes HUH.
  #318
Old 02-14-2014, 12:22 AM
You must be joking there is not a single runner the same length and the plenum is stupidly small.
That thing is a joke.
  #319
Old 02-14-2014, 01:23 AM
Originally Posted by MustangSix
Frankly, I'm a sceptic. I think it's unlikely you can hit 500 hp in a drivable engine without using forced induction.
We all know how poorly the HE head flows, but the pre-HE was not that much better. Porting the HE head still leaves you with a less-than-desireable chamber shape. Asking a V12 Jag to produce in excess of 1.5hp/ci is going to be a very high bar to reach.
These engines do well in categories of smoothness and panache, but have never been renowned for their power output.
I'm afraid that is all complete nonsense.
The Le Mans engines were making 100bhp/L with relatively mild cam timing, peak power before 7000rpm and ran for 24hrs at a time with no worries at all.
The Pre-HE has excellent breathing as it's a semi Heron extremely similar to the famous Ford kent x-flow engine. Those engines make easily up to 200bhp nowadays from 1800cc.
The basic problem always arises, the sheer dreadful thermal efficiency of the thing.
It has about all the worst aspects ever imagineable to make fuel effiency, no matter how jaguar said how wonderful it was.
In this respect, some US V8s are better, i can think of the LS series for instance.
One of the major hangups is the lack of space and the sheer weight of the V12 engine.
This makes it incredibly difficult to make a proper tuned exhaust for it, in anything other than a sports racing car (hence the Le Mans V12 worked).
If you REALLY want to tune a V12 to make 500bhp it's pretty straighforward, but first com up with a huge wad of cash and DRY SUMP the thing with a proper water system.
After that it's just mega money to do the heads & ancilliaries right with a proper inlet tract and EFI system,- in short all the things that were a design disaster on the original factory Jaguar.
  #320
Old 02-14-2014, 07:24 AM
warrjon's Avatar
I think Ron is referring to the AJ6 tubular manifold that has longer equal length runners, NOT the AJ6 modified stock Jaguar manifold.
Quick Reply: so has anyone actually made 500bhp from a v12 pre.he
