Sound system question XJS V12 1990
First you need to decide on what is going to in there. Features etc
When you have made your purchase installing it relatively easy as long as you have some basic skills and tools.
You will need
DMM
wire cutters
pliers
Soldering iron - I prefer to solder all connections rather than use those horrid cheap crimp connectors as they always come apart DO NOT just twist the wires together.
Once the old one is removed you need to identify where all of the wires go so they can be connected up to the new head unit.
=== edit === Oh you will need heatshrink tube to cover the wires
You will need
DMM
wire cutters
pliers
