source for hand brake micro switch?
A quick google of the part number brings this up:
https://www.britishparts.co.uk/produ...dbrake-DAC3351
Apparently this one also works: Low Cost Standard Microswitch with Roller | Maplin
gkazimir (08-25-2016)
I just bought one two weeks ago from Coventry West.
Coventry West - Jaguar and Land Rover Parts
Wasn't expensive, but I forget exactly what I paid since I bundled it with a few other things. It was used, but it worked great.
Cameronb (04-21-2018)
i'm looking for this switch too, but i suspect the DAC3351 is for the coupe. my convertible has a parking brake interlock for the droptop and there are three leads. this switch only has 2 spades on it. if anyone knows the part number for the switch with 3 spades, i'd be much obliged.
As you said, you need a three terminal microswitch which are NLA in the UK at least from Jaguar and the specialists. I ended up buying a pack of these:
https://www.amazon.fr/dp/B00E0JOTV8/...hvnetw=g&hvqmt=
https://www.aliexpress.com/item/5pcs...ceBeautifyAB=0
i ended up ordering this. it's a 16 amp switch like the DAC3351, but it's a Single Pole Double Throw. I expect to have to bend the actuator.
Greg in France (04-23-2018)
I think this one might work too: https://www.digikey.ca/product-detai...1C5-ND/2754900
Or this one: https://www.digikey.ca/product-detai...378-ND/1824838
There are lots to choose from.
XJsc-guy
06-25-2016 11:22 AM
