spark plug replacement
I have the later AJ16 engine with the coil on plugs.
It's very straightforward.
Pull the plug wires off, unscrew the plugs using a 5/8" socket (test the size on the new socket first to make sure?). You may need a socket extension?
Smear some antiseize on the threads of the new plugs to make sure the plugs don't lock in.
Screw in the new plug, making sure it's gapped properly. (0.035")
Torque them to 19 ft-lbs.
Plug the wires back on. You're done.
I'd recommend sticking with Champion brand, although people like the NGKs here as well.
If you see oil in the wells, it's time to change the spark plug gaskets....also straightforward and easy.
I sure do wish that the plugs on my V12 were so easy to reach! If you have a spark plug boot remover. It's just a flat pair of pliers with plastic covered jaws. Grab the top of the rubber boot and try to rotate it back and forth gently. I'm sure that the heat has bonded it to the cam cover. The boot pliers are available at any auto parts store.
Timeisrelative (02-08-2020)
Steve.c3h8
02-29-2016 07:20 AM
