Speedometer repair
Old 12-08-2017, 01:45 PM
Steve M's Avatar
Received 3,036 Likes on 1,702 Posts
The diff mounted speedo also has a circuit module which failed on mine. It is located in the boot (trunk) on the left hand side, very close to the boot light fitting with the wiring and plugs clipped up under the wing (fender) top.
I don't know if the trans mounted ones have a similar unit.
Old 12-08-2017, 01:59 PM
Jagboi64's Avatar
Received 3,184 Likes on 2,101 Posts
No, goes directly to the speedo/cruise/trip computer.
Old 12-09-2017, 01:50 AM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
Steve, great to hear from you. Your observations have been greatly missed, in France, anyway.
Greg
The following 2 users liked this post by Greg in France:
orangeblossom (12-09-2017), Steve M (12-09-2017)
Old 12-09-2017, 08:12 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
I found the 1984 to 1988.5 wiring buried in the wiring diagram.
These cars do have a speed interface unit item 165 in the attached, I could not find an item location for the speed interface unit. I would be tracing backwards from the speedo and check ALL connections and grounds before replacing anything.
The WY wire from 164 to 153 also goes to the speedo so this is the speed signal.
Item
153 Cruise Control ECU
154 Vacuum actuator
160 Switch
164 Speed transducer
165 Speed interface unit
167 Trip Computer
284 Kickdown inhibit switch
Old 12-09-2017, 09:14 PM
Doug's Avatar
Received 10,920 Likes on 7,174 Posts
Hmmm.
That diagram disagrees with the ones I have.
Mine show a yellow wire from the speedometer transducer ('pulse generator' in my diagrams) going to the speedo, trip computer, cruise control, and service interval counter with no interface....which is consistent with what I've actually found on the cars.
I wonder if what's being called a 'speed interface' is actually the fuel injection interface unit?
What's shown as a 'kickdown inhibit switch' shows in my diagrams as the gearshift mounted switch that allows the cruise control to engage only when the gearshift is in "D". No tie-in to the kick-down circuit.
Lot of the wire colors are different as well.
Old 12-09-2017, 10:47 PM
Jagboi64's Avatar
1984-1988.5 spans the VIN change between trans mounted transducer and the diff mounted pickup. I wonder if this diagram is for the later cars with the diff pickup?
Old 12-09-2017, 11:58 PM
Doug's Avatar
Bit of a mystery.
I have two diagrams each of the system using the diff mounted speed sensor and the system using the trans mounted transducer...and none seem agree with what Warrjon posted.
Oh well.
  #28
Old 12-10-2017, 02:27 PM
warrjon's Avatar
That diagram is from the 1984 to 1988.5 HE supplement from the Original Jaguar ROM
The wiring diagram is labeled
Wiring Diagram B
XJS 5.3 North American Spec upto but not including 1988 1/2 model year vehicles.
The diff mounted speed sensor is in the 1989 model year supplement so probably commenced some time in late 1988, my guess.
In my car the speedo and CC use 8000ppm and the TC uses 4000ppm, It would make sense that Jaguar used the same pulses for the pre diff speed sensor and did not update the CC and TC.
But who knows what Jaguar did, I have come across many inconsistencies in the documentation.
Old 12-10-2017, 05:51 PM
Doug's Avatar
Turns out I have the same diagram in one of my ROMs but never realized it.
The same ROM also has a fold-out diagram labeled 1988½ USA specification that appears to show correctly show the system with the diff mounted speed sensor. I say "appears" because I didn't scrutinize it in detail. Those all-on-one-giant-page diagrams are just too hard for me too read! It's hell getting old
  #30
Old 12-10-2017, 07:16 PM
BradsCat's Avatar
Next warm day of opportunity I'll get the instrument panel re-installed. My guess is the transducer is the speedo culprit. I am going to get a transducer off a local junkyard car rather than spend $100+ for a new one. Spent my budget on the smog pump manifold plugs and bracket assembly. Back to two or more steps forward and no steps backwards hopefully.
johnfrye
10-28-2009 12:21 PM
albatera
02-07-2008 03:04 PM
jdjag
08-16-2007 03:20 PM
jaggerknott
08-13-2007 09:10 AM
Quick Reply: Speedometer repair
