New day, new problem, basically i was trying to locate a misfire on my engine, was checking sensors, wiring, injector harness , pulling wires in and out, checked MAP vacuum line, fuel pressure vacuum, etc. During this work i started to get FF19 error on the computer, didnt really pay much attention, though its happened because i disconnected and reconnected smth, took car for a drive and it doesnt want to, it want to stall on D , unless i give it a bit of gas, doesnt run above 1500 RPM, i managed to get home literally by just slightly giving a gas and keep it bellow 1500, now i start to think this Code does mean smth, its doesnt go away after battery disconnected.
i found only few threads about it and still cant understand what exactly this code refers to, what i found is , its either MAP or TPs or smth else.
my ECU is 26CU , 1992 XJS 5.3 v12
Thanks for the help
So the easy TPS check as usually turned to a nightmare
First of all, my TPS doesnt have yellow, red and green. Instead it has red, green and black.
please see bellow
if i assume red is red and green is yellow , then V goes from idle - 0.24 to WOT 0.03
if i assume red is red and black is yellow, then V goes from 2.6 to 4.6
0ne wire carries a permanent 5V.
The wire with the variable voltage is the wire that gives the ECU the throttle signal. This should be 0.32v at closed throttle and 5v or 4.9 at wide open throttle. You adjust it by loosening the screws and turning it slightly one way or the other. Once the closed posotion is set that is it.
See attachment to post number 10 on this thrrad for the loom/tps wire colour match ups
thanks Greg, apparently on my Lucas 215SA TPS , green is throttle signal, black is ground and red is constant 5v
However, now im a bit concerned, i have seen few threads were its says that facelift 1992 5.3 TPS should be at 0.20, not 0.36. How can i confirm this?
Ok so my TPS was at 0.15, i set it at 0.36. And then car gave me 4 different codes each time i reconnect the battery
FF19, FF17, FF13, FF23. Last one seems to stay and repeats.
checked ECU grounds, checked CTS, Air temp sensor, TPS set at 0.31. Still im getting 17,19 and 23 code, when i put car in drive sometimes RPM starts to slowly go down to 0.
Update: in case someone will get into the same problem.
MAP vacuum taken from cross pipe at idle ( 16 inHG)
MAP vacuum taken at metal spigot at the trunk (10 inHG)
looks like i have a vacuum leak somewhere between crosspipe and ECU , if im thinking it right.
Update: Guess where my vacuum went?
Problem resolved! I hope that was the reason for overheating and bumpy idle.
