Steaming up!
Steaming up!
Hi all ,
After running the car upto temperature to tweak the aav, I spotted smoke coming through the front screen vents. In a panic I disconnected the battery and then realised there was no burning smell. The smoke was actually steam. So I'm guessing something to do with the heating system. I'm unfamiliar with this area, particularly behind the dash. Any ideas on what its likely to be and how to access the area. Also is it possible to clamp the pipe off in the engine bay so i can still drive the car.? Many thanks in advance
Brinny
This might be a heater matrix leaking.
Pressure test the system cold (pressure test kits are cheap on amazon). If it is I think, repeat think, it is possible to replace the matrix without having to remove the dash.
If it is actually the evaporator leaking, which it might be if the "steam" does not small of antifreeze, then it is a dash out job. Do-able, but a ROYAL pain.
Grant Francis (07-23-2023)
Greg in France (07-23-2023)
If you have functional a/c you might get some fogging of the windshield if the humidity is high. I would watch your evaporator drainage for coolant (the puddle under the car after the a/c has been on).
Kirby’s book says you can change the heater core without taking out the dash on Delanaire III, which I believe all your cars have.
The following 2 users liked this post by RGK20m3:
Greg in France (07-23-2023),
leep123 (07-23-2023)
The Del III system was introduced in late calendar year 1986 and the fastest way to identify which system is in place is to simply look at the temp control dial. The Del III has the "Pull for manual control" feature. The Del II does not.
The following 2 users liked this post by Doug:
Glennbar66
11-26-2012 04:28 AM
2003 S-Type
62
04-04-2012 08:08 AM
