Steering and gearshift screwed up
Turned ignition off took out key and steering no longer locks and you can put in R,N,D without pressing brake also you can put in any gear without key in ignition and no foot on brake. I have not mucked with anything it just happened.
Could steering possibly lock up while driving ?
Maybe our cars were different, but I do NOT recall a gearlever interlock in the Pre 1994 cars. Maybe the US of A cars got it, no idea why.
I thought it only arrived with the J Gate system.
The steering lock is possibly just a gummed up plunger in the barrel, after all it is OLD now. Remove those 2 shear bolts, and lube that plunger, refit with new shear bolts, or standard bolts.
Panic not, she will know, and mess with your head even more.
Steering used to lock
What about the shifter ?
Received 10,988 Likes
Grant Francis (01-01-2018)
l can only speak for the V12 cars l have, none of them have any form of gear lockout.
gavinw35
05-19-2012 06:37 AM
frombenz2jag
01-10-2008 08:08 AM
