Steering rack bushes guidance
Eveing all,
I am fitting polybushes to my XJS 5.3 v12 steering rack, the old ones were utterly shot,
The new bushes are about 50 thou thinner on the steel centre pin than the original,
My question is, with standard bushes and therefore polybushes , should there be steel washers on the end of the poly bushes to take up any slack that would exist when putting the bush into the mounting frame ???
I am unable to rely on what was originally fitted as others had had the rack off before I got the car. so I have no reference.
If anybody can guide, I would be grateful.
Hi all,
To update a little, I have another query, the wrist pins supplied are smaller in length than the bushes when assembled.
should I pack the centre pin out to the width of the bush, ??some measurements below;
Mounting frame width is 45 mm
Wrist pin length is 39.7 mm
Polybushes width are 42mm
So, should I pack out both the centre pin, and the poly bush to the width of the mounting point ( 45 mm)
Would appreciate any guidance on this subject
Hi all,
Jon
Received 10,871 Likes
Greg in France (07-25-2022)
Noah
06-18-2022 08:15 PM
