Steering rack rebuilt help
Hello guys!
I started to rebuild my dads jag and i need some help with the steering rack. It leaks and i need to change the seals. I want to know how can i open the steering tower and how can i change inner steering rod seals?
All kind of info is welcome!
Thank you!
Mark
Thank you!
Mark
Here are some pictures
http://s24.postimg.org/puyzcppx1/image.jpg
http://s24.postimg.org/hqvglpsvp/image.jpg
http://s24.postimg.org/9vgbt5tv9/image.jpg
http://s24.postimg.org/5jrq45myd/image.jpg
http://s24.postimg.org/uw6de2xdh/image.jpg
http://s24.postimg.org/cun8ga3cl/image.jpg
http://s24.postimg.org/6r5nwdd2t/image.jpg
Rack rebuild
I had exactly the same problem a year ago. My XJS only had 116000 on the clock so I thought a seal kit would suffice. Unfortunately after dismantling we found the rack shaft was excessively worn. I had to have a local company hardchrome & grind the shaft then reassemble & pressure test the completed rack. Ended up being a $1000 job. Bad experience all round.
