Steering rack swapover
So now, as continuing repairs after my date with a retaining wall, my steering rack is leaking. MY 92
Dropped the old rack yesterday. Surprisingly it was an Adwest.
i have the ZF rack from the 1991 donor car.
From what Ive read, this seems a bit backward. And I suppose I am going to have to convert the ends on my new hoses to metric....
Received 10,873 Likes
I dunno.
But I think you're right about the ZF fittings being different than Adwest
My understanding is that A) using the ZF rack requires hoses to match and B) the hoses are the same at the pump end but different at the rack end
Others will chime in to clarify, I'm sure
Doug (10-29-2019)
Greg in France (10-29-2019)
Well I never. The reason I had to use new pipes when I changed to a ZF rack was that the actual bends on the Adwest pipes would not fit the ZF. But mine is RHD, so maybe different?
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/472c2279_f24b_4b76_bed4_97c008376151_87af2192f23e42a82c4068093345187c830dba86.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/f32e77de_9f47_46e4_9b66_b15a0d437c04_6c480bea9c3f5c3504b16262386fd47d2adac8d2.jpeg)
A new question. Somewhere along the way, someone has lost the pinch bolt for the joint that attaches to the pinion rack. I have to use a standard 5/16 bolt for the moment.
But the threads are too large to slip through joint without being ‘threaded’ with a ratchet.
Is there a special bolt for the pinch fitting?
I would find the Metric equivalent of 5/16ths and shave a bit off of that. Say, 7.5mm. try McMaster Carr...?
Oh! I see said the blind man...
Is the nut and bolt being replaced the one that was removed,,, the very same one? Was it tough to remove as well? If not, strange. Maybe work on the 'grove' in the tower gear that must be found when replacing - which ain't much fun in itself - to see if it has been narrled or misshapen a little? Seems you're only oft by a little bit. A rounded right shaped file perhaps, to clear the channel...?
Yeah,,, I'm a bit Barney Rubble or Fred Flintstone compared to most of the good guys here.
I wouldn't pay someone to work on my truly life giving little car projects,,,, if you paid me, lol...
I'm sounding like a PITA hard liner or sumpthin,,, I ain't that. But I do enjoy doing the work enough that I wouldn't pay. That's just me.
I totally agree with you. I love wrenching.
But Im only wi5h my cars a short time each year. And now Im getting ready to sell the apartment building where I keep them, so Im moving them from Baltimore to Seattle
So this season it was replace the subframes and rack on the Jag, get new wheels and tires, and paint it after all the repairs.
Then my TVR is getting a body off mechanical restoration and rewiring. This weekend I roll it to a paint shop that Ive rented the booth for 4 days so I can do a complete spray job.
And Im pulling the engine out of the 928 to re-gasket it, replacing halfshafts, new clutch and shifter linkage.
And this month I still have to reassemble my diesel 6 cylinder boat engine before I head back to Africa for the winter.
So, there are times I need a bit of a helping hand...
In that case,,, pay the man,,, hahaha
You PAINT!!!? Do you teach!?
I just googled trv... You're living large.
I was an occupyer of occupy wall street. Governance and structure area. Policy guy. Like organizational structure of the movement building type... Life long activist... Pretty good at it. I've been in NYC living in the margins since 2011. Long story. Book worthy, maybe.
These cars have been a gift. Just happened. It's now a bit of a passion. I'm in it. A Russian man who I've met in my travels here has been collecting them in his yard forbuears where they became nests for mice. Damn shame... I feel lucky. He basically gives them to me. I have my eye on another of 3 928s he has left. Manual 85...
Anyways. It sounds like you have an interesting life. Thanks for telling!
Yeah! Pay the guy! Lol
