Steering rack zerk
ALL mine had that fitting, either as they came or fitted by me.
It was, yes, deleted, and a plug fitted, as access to that hole is required to centralise the rack for alignment purpose.
YES
Over greasing will gum up the works, blow seals, NAH, very doubtful, unless the "greaser" has pumped a full pale of grease in there, so I suppose that is possible. Common Sense is a dying commodity in MY opinion.
Mine AL,L get 2 squirts in there from one of those Mini Grase Pistol Guns, annually. I use Wheel Bearing grease in all the fittings in all the cars.
There is NO way of telling if its full. It does NOT need to be full, it is simply greasing the Nylon wear pad on the rack piston, so a LITTLE is a LOT for this purpose.
YES
The following 3 users liked this post by Grant Francis:
Jagsandmgs
04-27-2018 05:17 AM
