Stereo and power antenna wiring question
Hi guys,
New owner of a 1993 XJS 4.0 in Montreal, Canada. I have two questions about stereo wiring. Hopefully someone can help out.
1. Stereo Main Plug:
Other than the speaker wires (which are labeled on the car side), I have 4 wires (see attached pic):
- Purple
- White/blue
- White/Red
- Yellow/Green
According to the wiring diagram in the service manual, I should see:
- Purple/orange (radio and telephone tranceiver)
- White/blue (power ignition)
- Purple (radio memory)
- Red / pink (not sure...)
I'm a little confused here and have trouble figuring things out. Can someone help me identifying the wires that I have on my stereo plug?
2. Power Antenna:
The power antenna is defective (doesn't retract). I've pulled out the unit (eventually I'll try to repair it) and replaced it with a Hirschman manual version. The power antenna was grounded to the chassis, behind the RH tail light. Am I going to have a grounding issue if I just leave the power antenna 3-lead connector (purple/white/black wires) and ground lead disconnected?
Thanks in advance for your help.
Paul
- Purple
- White/blue
- White/Red
- Yellow/Green
2. Power Antenna:
Paul
Paul_59
04-03-2016 04:55 AM
