Strange connector in centre console
Hi Gents (and ladies)
Hoping someone on here might be able to identify what this connectors for?
I have a 1994 facelift 6.0 V12 and discovered this connector a while ago. Its like no other connector I have seen on the car and I'm curious as to what it could be for. It does appear to be part of the Jaguar loom.
Any thoughts?
Rob
Any thoughts?
Rob
The following 2 users liked this post by bullittandy:
Flint Ironstag (07-26-2017),
krakenfelt (06-18-2021)
Thanks gents for the responses so far. Some interesting suggestions to say the least!
XJSrookie, yes the car did have a phone installed when I got the car but it was a bodge job in my opinion and I doubt oem as some of the wiring was spliced into other wiring going to the radio. So this could well be the right answer.
Steve M, the connectors in front are the same as other jags, rectangular. This is why I was particularly intrigued by the connector as its like no other I have found on the car.
XJSV12, another interesting suggestion but it seems like a curious location to put something like that. I would have thought it more likely to be in the engine bay. Also I have never heard of self levelling lights on an XJS. Would be interested to know if anyone has one!?
Bullettandy, as per Steve M It's only this connector that's different.
Once again thanks for the suggestions so far. I think I like Rookies suggestion the most so far as it does seem the most likely but happy to be proven wrong.
Regards
Rob
Regards
Rob
Received 2,399 Likes
Although, having no XJS, I have no vote, I vote that is ledft over from the car phone.
Radio involved ? Slick, I recall that some of the car hones used the radio speakers for a hands off effect.
My 88 Tbird had a similar install. I liked it a lot. Air time, then was $$$$
My 94 Jeep has some of it's former car phone stuff still there. No hand set, though. Harmless, so I leave it there,.
Carl.
Carl.
Thanks guys.
It's not a concern, just curiosity on my part. As some have already mentioned, has no effect on the performance of the car.
I might see if I can get the meter on it next time I'm working on the car.
Would be interesting to see if anyone else on here has this connector or better still the genuine Jag phone plugged into it
Interesting, part 4 on the drawing Part no. DAC7244 | Control switch parts from Jaguar Classic Parts UK looks like the ignition switch on a RH Drive car. Did Jaguar ever offer a console mounted ignition or a Push Button Starter?
I wanted to show this:
+ Headlamp levelling switch
+ assembly
DAC11266
DAC11266 £41.60
http://www.jaguarclassicparts.com/uk...-column-switch
+ assembly
DAC11266
DAC11266 £41.60
Good spot XJSv12 the connector next to item 10. does look like the same connector I have . Sadly my car had been converted to quad headlights prior to my ownership so I have no easy way of finding out if it did have self levelling lights.
If it did, still seems like a curious place to stick the connector, under the centre console next to the window switches.
Please keep all the suggestions coming in!
Rob
Rob
adpock
XE ( X760 )
03-07-2016 10:51 AM
