Stupid question...how do I assemble the battery box? (aka sorting out my boot)
I have both halves of the plastic box that covers the battery and sump tank but I can't for the life of me figure out how they are supposed to go together, and close, and cover all the stuff. I even looked at pictures of well-sorted cars on eBay and stuff. I assume one half has to slide underneath the sump tank, the other half sits on top and the half-turn plastic screws pass through both plastic halves into the two holes in the battery tray? Or no?
And while I'm on the subject, what holds the carpeting covering the fuel tank? It looks like crap just hanging there all wrinkly and flaccid. I thought about at least spray-gluing it to some cardboard or something.
And is there a piece of carpet that sits under the spare tire (in the recess where the drain holes / plugs are)? I may be missing that piece if there is supposed to be one there.
I finally got my boot lights and my power antenna fixed (not long after pulling my gas tank 3 times) so now I want to get this boot area looking nice and sorted out.
Thanks!
Thanks!
A couple of pics I hope will help. Bolt in the metal structure that covers the sump tank first, not too easy to get on the lower bolts. Then the plastic cover goes into the obvious holes on the metal structure.
As original, on my '85, there was no carpet under the spare wheel.
The carpet covering the tank was just fixed at the top by a few dabs of glue originally. When I redid mine, I spray glued it at the top and a little down the sides. But you need to make sure you can get to the filter to change it though. In my case, the carpet has a large square cut out hidden behind the spare. The fuel sender and the filter are all accessible that way.
![](http://i1010.photobucket.com/albums/af224/bokapita/DSCF4422.jpg)
![](http://i1010.photobucket.com/albums/af224/bokapita/DSCF4421.jpg)
![](http://i1010.photobucket.com/albums/af224/bokapita/IMG_1336.jpg)
Greg
Greg,
Thanks, I now see I'm missing that metal plate. And here I was trying to line it up with the bolt holes, as well as trying to put the two halves on top of one another (I can see in your pics they are offset and the top one rides over the wheelwell). I'll have to look around and see if I can dig up that metal plate somewhere.
Thanks!
D
Thanks!
D
al_roethlisberger
09-11-2015 10:04 PM
deanh
09-06-2015 08:20 PM
