Supercharged V12 info please :P
Does anyone have any information on how good the stock heads are even with mildly oversized valves and a 70/30 cam ?
I've already purchased a 7L crank from Rob Beere, Carillo rods ( gotta love the exchange rate!) , 96mm liners from RBR, high capacity oil pump again RBR and a set of extractors from Spiteri Jaguar here in Melbourne. So I'm kinda committed to a 7.3 beast, but finding out about everything below the cylinder head gasket has been relatively easy. When you start digging around for knowledge on the cylinder heads, you come up blank. If anyone can help or point me in the right direction, I'd appreciate it.
Forget Spiteri they are really expensive - talk to Norman at the EType Factory in Melbourne he knows more about getting power from the V12 than almost anyone. And his pricing is pretty good.
mfzr01 (03-05-2013)
I am building a 6.8 v12 with flatheads and am tossing ariund the udea of what crank to use. what do you have there?
#28
the intakes will flow 1200cfm so that is enough for a ton of hp. but if you want that to be easier go with the v12 sales intakes. they are designed for 500+ applications.
#30
this guy cut and spliced the intakes together to cover the valled. pretty cool.but one could do this a ton easier with piping and elbows
#31
[QUOTE=calvindoesntknow;710116]
Pin size I don't think is a problem NASCAR run 1.88 journals, they need to be properly ground and radiused. You would also need to weld and re-drill the oil galleries.
read this
Crankshaft Technology - Rotational Rationale On Bottom Ends - Circle Track Magazine
read this
#32
still happening , just slower than I anticipated
Well its been a little while. Still havent started. I got sidetracked with a boat and a V8 Lexus conversion for a transit van which Im in the middle of. The V12 is still on the cards, but probably not for another year yet. Have to finish the transit and save up for the V12 bits.
To Sean I will be in touch early next year or later this year as finances allow.
To Warrjon I will take delivery of the XJC soon and have a spare xj12 sitting here as donor engine car to play with.
Always wanted an original V12 xjc, didnt realise it takes sooooo many years for things to happen...
Oh, had wedding anniversary a few months ago. Married life is Bliss...
#33
Twr blocks
hi Sean b my name is George and I'm starting my research on my next build being an xjs v12 and was wondering what the differences are between the twr blocks and standard. Also how much is a twr block worth?
#34
Conrods even though they were forged were a weak point.
#35
with 12:1 compression ratio the only way to turbo or super charge an engine is to provide some type of charge cooling.... WWII aircraft relied upon alcohol and water injection to provide charge cooling and to prevent detonation...
for the Jaguar V12 the best bang for the buck is something that provides charge cooling and more Oxygen: wet nitrous... wet meaning that you also provide fuel with the nitrous...
#36
You're probably thinking of Bradley Smith's XJS:
Bradley Smith XJS in Detail
He passed away a few years ago. The car comes up on Ebay now and again
Jaguar 1985 XJS twin super charged
#37
Unfortunately George lives in Sydney, NOX is illegal on the street here, can have the bottle installed but it must be physically disconnected.
#38
George there is a load of information on this site pertaining to modifying the V12. It would help if you could give a little information.
What is your budget, what are you trying to achieve and the model of your car, the V12 had numerous iterations, there are 5x V12 block part numbers depending on year model.
#39
Thanks for input guys , just starting to gather as much info as possible at the moment . Sourcing a forged crank right now an original twr unit , the block I would prefer to use a new item but don't know how much there going for. In regards to turbos and compression, I've built a bmw e30 with a 1 jz so the theory I thought would be the same in regards to comps and boost 8.5 to 9 comp and boost according to the motor and tune. As long as the bits are up to it like forged crank , rods and pistons, arp studs , fuel supply and a good control unit, I'm thinking it should work. Budget is somthing that is never even close so I'll say that what ever it takes with myself doing a lot of the work. The aim is to build it correct no short cuts but done right , without spending 1 million dollars. Does anyone know what a new block is worth?
