Suspension/steering noise/clunk, help needed
I REALLY hate threads like this so my apologies. Its very hard to diagnosis noises via the web and impossible even with video.
EVERYTHING in my front suspension and steering is new. I've checked suspension loaded and unloaded and can't see any movement or recreate noise.
The noise sounds like a bad MacPherson strut mount. Not harsh, not metallic, not obviously broken, again, just a bad Macpherson strut mount.
I've got the original style (foam?) shock bushings on the shocks, they seem like a good culprit except that they are new.
I'm going to replace them to troubleshoot but does anyone have any other ideas?
Received 10,871 Likes
Rhett (05-01-2016)
As well as Doug's important point, check that you have the special washers for the shock top mounts and that they are mounted correctly. They have a slightly protruding centre which should be facing into the hole in the body, both sides, top and bottom, facing into the hole.
If your stub axles are worn and not yet renewed, they can cause it Andy, that is my guess if all else is new, or a loose steering arm bolt also a possibility...
Greg
Greg
orangeblossom (05-01-2016)
I renewed my own stub axles recently due to a "baby" clunk (so slight only the owner would pick it up) in the front end when negotiating slight ridges/imperfections in road surface.
Fixed it beautifully. Bonus was new stubs required light drive fitting of bearings so rotation/wear should not be a future problem.
Rhett (05-01-2016)
I have an intermittent clunk coming from the right front of my XJ-S when going over slight dips in the road or turning left into parking lots and driveways where the right wheel is momentarily lower than the left. It's intermittent and fairly subtle but I hear it every time it happens. In every other regard, my car feels very solid.
I don't know if this is what you're all describing but I appreciate the ideas you've all posted.
Rhett (05-01-2016)
+1
I also really tightened lower shock bolt in reference to Doug's suggestion.
Rhett (05-05-2016)
oldish git
27
07-24-2020 02:05 PM
robearner
04-02-2016 03:51 PM
