Swap out Spark Plugs on HE
#101
You can get GXL wire from Bursons Auto Parts, at least I can in Warrnambool.
or on eBay
11 AUTOMOTIVE WIRE 16 GAUGE GXL WIRE ELEVEN COLORS 25' EACH COLOR 275' HIGH TEMP | eBay
Also get yourself a crimping tool and crimp the injector connectors directly to the new harness.
or on eBay
orangeblossom (10-26-2016)
#102
G'day Guys
I decided to move the thread over to here, now the topic has changed from plugs to the injector harness:
https://www.jaguarforums.com/forum/x...3/#post1559581
cheers
cheers
orangeblossom (10-28-2016)
#103
when I redid my injector loom, I kept the old plug in at the end of the harness since the wire was still pliable. I also made use of a board for laying out the wires, following the old wires one at time as I went along.
instead of making a diagram, I mounted poster bard on a piece of plywood I had and use self stick 3m hooks then ran the wires according to the old
did leave plenty of extra and saved the old connector with a pig tail to connect new wires to
The following 2 users liked this post by daverb:
orangeblossom (10-30-2016),
paulyling (10-30-2016)
#104
That is a great idea Dave cheers. Some of the other chaps had mentioned the same idea also. I think I will definitely copy this method
I am just going to move your post over to this thread:
https://www.jaguarforums.com/forum/x...ss-h-e-171613/
The following 2 users liked this post by paulyling:
Grant Francis (11-03-2016),
#105
I'm changing my plugs as well, along with spark plug wires, dizzy cover and rotor. We will see if I end up doing injector harness as well, but for now it's not the plan
David Manners tells me they will supply NGK BR7EFS for my 1989 eurospec non-Marelli 5.3 HE.
In post #6 in this thread Grant Francis tell us he uses BPR6EF
I will get a colder plug without projected insulator, but with copper core.
Thread, reach and cone is similar, so it will fit, but is it what I want ?
Cold will foul up before a hotter plug, but will also resist heat better. As long as I'm not racing the car I suppose 6 is better than 7.
NG decoder (in english...):
https://www.ngk.de/fileadmin/Dokumen...en_code_en.pdf
The following 2 users liked this post by leo_denmark:
orangeblossom (11-03-2016),
paulyling (11-03-2016)
#106
#107
#108
The following 5 users liked this post by Greg in France:
leo_denmark (11-03-2016),
paulyling (11-03-2016),
ronbros (11-03-2016)
#109
#110
#111
Having just removed mine (for the first time) .. Very scary.. had to soak them all for a week in Penetrene etc.. I had to use a 1m breaker bar on some VERRY tight plugs. Note GF's advice and remove the Dizzy cap to get at plugs 3 and 4. There were fragments of my previous cap floating around in my V.. And use never seeze grease on new plugs for next time and tighten only to 10lbf/ 1/16 turn!
The following 4 users liked this post by PaulRoper:
leo_denmark (11-04-2016),
orangeblossom (11-04-2016),
paulyling (01-26-2017)
#112
I have run the "6" in the HE for years, and I drive HARD, the wife HARDER, and no issues ever.
The PreHE gets "5" coz thats hers, and that gets caned.
I also use the "P" on the HE to get the spark out into the swirl chamber, as apposed to up inside itself, just works for me. We also got 12.5:1 comp, so the plugs do work hard.
Different climate by a long shot to yours, so your choice I suppose.
Different fuels also.
Greg has advised WELL, and his climate/etc would be similar to yours.
The following 4 users liked this post by Grant Francis:
Dr Quail (02-25-2017),
Greg in France (11-04-2016),
Gerry755
08-31-2016 07:49 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
