tachometer for v12
I think I remember reading somewhere that the tach for the v12 with a marelli ignition is a 6 cyl tach. Since the ignition system has 2 coils and is basically 2 six cyl systems merged together, it just reads off of one of the coils. Maybe it was in the "experience" book I read it.
howlinowl
howlinowl
howlinowl
howlinowl
There are 2 ways around this either find a Tacho that supports 12 cylinders???? or use a timing circuit to halve the number of pulses and use a 6 cylinder tacho. I'll have a think about the circuit and get back to you. Should be able to do it with a 555 timer.
Spot on - This is because the Marelli has one coil for each bank of 6 as apposed to the Lucas that even though it has 2 coils both coils run 12 cylinders.
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
Ok easiest way would be to find a KIT for a 555 timer frequency divider, could also be called a monostable vibrator.
I have attached a circuit I borrowed from the WWW. You could use a trim pot for R1 that will allow you calibrate your tacho. The V12 signal is approx 12MHz at 6500rpm so C1 and R1 would need to be sized for this frequency.
Or you could try these out they say they work with almost any engine swap combination.
Dakota Digital Universal Tachometer Signal Interfaces - SummitRacing.com
FS[Western US]: XJS V12 Convertible
marklcap
09-29-2015 12:41 PM
