tail light conundrum
Please offer any ideas or solutions.
XJS 2+2 4.0 1994 tail light issues. On the rear fenders there are two lights on each side, the outer clear lens lights are turn signals and they both work. The inner red lens are a shared tail light and brake light and they both work. On the rear rear boot lid there are two lights on each side. the outer lights are clear lens and they are reverse lights and they both work. the two license plate lights both work. it is only the inner 2 red lens that don't work. The reverse lights and these two red lens share a common neutral. Bulbs, fuses, and relays are good. I am assuming that these 2 red lens are tail light only fixtures, The bulb holder sockets are good, as I tested these with a 9 volt battery and the filaments lighted up, but very weak. The wiring harness travels thru the boot lid and exits just above the convertible hood pump, it goes into the rear right fender well and then seems to head towards the front of the car. I would need to remove the fender well cover which hold the boot lid strut, to confirm. Is there possibly a relay I am overlooking?
John
John
Maybe just tap the feed to the two lid-mounted tail lights into the license lamps? They are/ should be illuminated at the same time….running light wattage is pretty low and I am sure the circuit can handle another amp or so.
Perhaps there is one of those silly “lamp out” relays for it, maybe under ski slope?
Greg in France (01-28-2024)
Paul,
You are correct, to the left of the trip computer there are 2 rectangular buttons. One is for the rear fog lights and the other for rear windshield heater. The relay and fuse for the rear fog lights is under the driver knee bolster, both tested good, but I put in new ones anyway. the next thing to check I think would be the shorting plug, but what is its function and where is it located, and can I remove it? It probably goes thru the dash to the ski slope to the rear.
John
John
Glad it helped. NOW instructions from an European lol. Don't just put them on and forget them, they are bright for the driver behind you. My rule of thumb is in heavy.rain, if see the car in front before l see the rear lights. l put on my rear fogs. Same in thick fog. Dont forget to turn them off when back in the clear....
