Tail Light problem
The tail lights in the trunk lid (boot?) are not working. All other lights are working, license plate, reverse, third brake light. The lower tail lights and brake lights are working. I have checked all bulbs and fuses. Everything seems fine except the 2 red tail lights in the lid. I also have a Bulb fault indicator light when I apply the brakes. I have gone thru the electrical diagrams.
Any ideas?
Thanks...Jimmy
Any ideas?
Thanks...Jimmy
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/317x159/rearfogs_e2ac8d6895b419a22e1826b04c63cd0720b51311.jpg)
The outer lights are the indicator/direction light, then the rear/brake lights, the next are reverse/backup lights, then are the rear fog lights (not found on many types of US cars. Which is why many US driver dont know about them), and the last ones are the fake/filler light.
The rear fog lights are controlled by a switch under the steering wheel, next to the front fog light switch.The light switch must be on for these to work.
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/225x225/fogswitch_9caefefff59940761208fb6d69511a703d97a112.jpg)
I had the same problem with the warning light with my brakes. Have someone look when you press the brake pedal that the 2 brake light bulbs do illuminate, mine had a loose contact and only worked when it felt like it.
JayCee (11-24-2015)
JayCee (11-24-2015)
JayCee (11-24-2015)
DONT DO THAT !!.......They are as bright as the brake lights and will p;ss everyone off behind ya. Use them in Fog, Snow or heavy rain as extra rear protection. Remember always to turn them off.
The light failure lamp will only illuminate for a short time when first started not everytime you use the brakes.
JayCee (11-24-2015)
JayCee (11-24-2015)
JayCee (11-25-2015)
Thanks Steve,
I thought about that, but have not had a chance to look into it. I don't have a light on from the hand brake , but there could be a circuit failure. I will look through the electric diagrams and check it out. I noticed that I do not have to apply the hand brake when raising and lowering the conv. top. So the circuitry may be thinking that the hand brake is on when it is not. This could be the whole problem.
Thanks...Jimmy
Thanks...Jimmy
Yes. The hand brake seems to be working properly. Since the bulb failure light is suppose to come on with the hand brake on and brake peddle depressed, there might be something else in that circuit that thinks the hand brake is on all the time. I'll go thru everything in the electrical schematic.
Thanks...Jimmy
Thanks...Jimmy
Charlroi19
11-02-2015 06:43 AM
