Telescoping Steering Wheel/Column Adjustment
Hello All,
After about of years worth of fits and starts, (and many dollars) my rescued '89 XJS can finally be driven with a fair amount of confidence. In fact, I've found that the more I drive it, the better it seems to run!
At any rate, now that I'm spending more time behind the wheel and becoming more acquainted with some of the car's quirks, I've noticed that I cannot seem to get the telescoping column/steering wheel adjuster collar tight enough to keep the wheel/column in a locked position. I've been cranking it down tight enough to require two hands to loosen it, however, the wheel/column will telescope in or out during certain driving maneuvers.
Anyone have experience with a fix for this, or is this normal?
Received 2,399 Likes
Most common issue with that I have found over the years is item #16 in the attached parts drawing.
They are the 2 split collets that "grip" the steering shaft when that outer collar is tightened.
Some have one collet missing.
Some have had one or both collets broken.
One had SOOOOOOO much grease in there, they simply had NO hope of gripping.
Once sorted, that collar does not need to be super tight to hold the shaft.
![Telescoping Steering Wheel/Column Adjustment-jag-steering-wheel-bits.png](https://www.jaguarforums.com/forum/attachments/xjs-x27-32/132755d1467782491t-telescoping-steering-wheel-column-adjustment-jag-steering-wheel-bits.png)
orangeblossom (07-06-2016)
Thanks Guys!
I might have to put this issue down to operator error.
I tightened the ring with the wheel in the rearmost position and it magically locked down nicely.
Is the wheel only lockable in 2 positions - in or out?
I had assumed I could lock the when in any position.
Thanks Guys!
orangeblossom (07-11-2016)
The following 3 users liked this post by Greg in France:
yidal8
05-02-2016 08:40 AM
