Temperature Gauge Reading Very Low at Speed
Old 08-14-2022, 12:28 PM
campbellrobinson2001's Avatar
Very helpful information, I will definitely look into this valve on my car and see if it seems to be blocking flow from the cross pipe to the banjo bolt area.
Old 08-14-2022, 12:32 PM
Thank you all
Old 08-14-2022, 02:25 PM
Greg in France's Avatar
Received 9,375 Likes on 5,496 Posts
Originally Posted by Robbo D
I didn’t know there was a valve in there until a couple of days ago when I came across that thread. I couldn’t see the logic in the way it was fitted as it stops anything leaving the filler tube. I couldn’t pull mine out so put a drill through it after stuffing a rag in the filler pipe to catch any bits. I also enlarged the hole in the banjo bolt. Definitely bleeds a lot better now with no air in the central filling pipe or the coolant tank on the inner wing.
Rob.
Before I upgraded my cooling system, I did the same. Big improvement.
Robbo D (08-14-2022)
Robert Scott Neilly
01-16-2021 09:51 AM
88xj-sc
09-16-2014 07:58 PM
yeldogt
04-11-2012 08:21 PM
Quick Reply: Temperature Gauge Reading Very Low at Speed
