testing for injector harness short
Disconnect at the ecu and using a continuity tester and the circuit diagram test for shorts between each pin and every other pin of the ecu connector. And maybe between each pin and ground also. That's what I would do anyway.
where to test
since the injectors always have voltage and are pulsed with ecm provided ground, there must? be a short to ground on the ground side, to hold the injectors wide open, and since there are 3 sets that pulse individually where is there a common ground wire the could be shorted to ground?
Brake buster (03-17-2021)
From there you'll see 4 different wire colors which I believe all have 12v. The remaining will be your ground... Again, I think. Proceed with caution. But just do it
The KB wires I think are ground triggers, where K is PINK?
You'll have to look up jaguar wire color key.
EDIT: I'm sorry, I believe the KB wires are the positives while the O and xxxx are the negatives thru the resistor pack... My bad...
EDIT X2: Sorry, I think they are ALL positive as fed by KB and grounded (like was said) in the ECU itself?
I have a LOT to learn...
Someone help me out here, lol
Thanks BB... I had it kinda sideways.
just a thought
I had a similar problem a while ago, ran really rich to the point of stalling and wouldn't rev due to too much fuel, and it turned out to be the coolant temp sensor open circuit, cleaned connector and all came good.
