Teves ABS Reader?
Would it benefit me at all to get a Kent Moore J-38716 Breakout, or Pinout Box to read ABS codes on my 96 XJS?
I know it may not flash code numbers, but will I be able to find the faults that the ABS light is trying to tell me?
I don't think I understand what the capabilities of this tool is.
Hard to say. If all the Teves systems are exactly the same for every car manufacturer, then you should be ok. However, knowing Jaguar, they probably added their own little twist ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
All said, even knowing the various values may not necessarily indicate what's wrong with your system. If they are cheap then maybe taking a flyer is ok?
Cheers,
Allan
Cheers,
Allan
goges
10-05-2015 04:53 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
