TH400 oil pan with drain plug for the V12?
Hey guys,
I'm having some issues with oil pans (sumps) for the TH400...
There are deep and "normal" ones for the standard V8 TH400. These will fit the tranny, but the problem is, they aren't deep enough for the V12's transmission. My factory sumps are about 8 cm deep. The ones offered for other brands as a DEEP sump are like only 6 cm deep, tops. Most are more shallow.
Has anyone managed to source a sump with drain plug for the V12 with enough depth so the V12 won't cook the transmission (more fluid = cooler transmission = better life expectancy)...?
Damien
Damien
Received 10,872 Likes
This fits mine OK, Daim:
https://www.jegs.com/i/Moroso/710/42020/10002/-1
https://www.jegs.com/i/JEGS/555/60179/10002/-1
At 3-1/2" it would be perfect... As I need a new selector shaft, it looks like Jegs is all the way to go...
Cheers GIF!
I drilled a hole in the existing pan and added a drain plug. https://www.jegs.com/i/JEGS/555/60175/10002/-1
I wouldn’t say it leaks, but it sure is damp and seems cheaply made. But man six bucks beats $200 every day.
ronbros (07-07-2018)
Awesome! Jegs also has a standard sump/oil pan... Seems like the same just without thouse front openings...
Cheers GIF!
Cheers GIF!
I'm not so worried about the fluid left in the sump, as every fluid change involves a filter replacement and therefore the removal of the sunp, as long as I can drain 'most' the fluid I'd be happy.
Regarding the cast vs. pressed/stamped/welded pans... Hard thing to decide on. Most modern sumps are cast. Even engine sumps... So I guess that may have been imporved? But at the same time, for something to smash into the sump, big enough or with enough force to crack it, then it would have causes some damage else where before hitzig the oil pan (which is so far back).
I don't plan on speed ing with the V12. A steady 130 kph will do me... Even with the unrestricted Autobahns here. The only worry I have is, where to fit the sump magnets... Aluminium isn't magnetic and I don't think a magnetic plug will do enough to catch the shavings (though mine should have less, as the running in phase for the planetary gear etc. is long gone (1989 to be precise ). So anything which is found can only be tiny which would get caught in the filter anyway...
I The only worry I have is, where to fit the sump magnets... Aluminium isn't magnetic and I don't think a magnetic plug will do enough to catch the shavings (though mine should have less, as the running in phase for the planetary gear etc. is long gone (1989 to be precise ). So anything which is found can only be tiny which would get caught in the filter anyway...
Problem then is removing it for cleaning I might epoxy a piece of steel though and then the magnet would 'stick' to that...
Jon89
07-31-2014 10:39 AM
Jon89
02-22-2011 05:33 AM
