Is there a source for the 4.0 facelift AC hoses
These are sadly 1st generation 134a ball valve style soldered right to the hard line. AC is probably the only way.
Spot on. I removed the low side fitting and the 5lbs of pressure in the system shot that ball valve across my garage into oblivion. I will have two new valve-core style fittings here tomorrow thanks to another post here with the O'riely part numbers. Then a quick vac down and recharge. I suppose I should have put my recovery machine on it but I really thought it was empty.
chXFS
05-30-2022 11:02 PM
CruizinKev
10-09-2017 09:12 AM
