Thermostat gasket, not “O” ring ?
Going waaaay out on a limb here.
You have a 6cyl car ???
If your ID is a give away a 1995 AJ16 engined beast??
AJ6 and AJ16 are the same Stat.
AJ6 has an o/ring, and the cover is to suit that o/ring.
AJ16 has a Gasket, and the cover is to suit that Gasket
Put an o/ring on an AJ16 and you WILL break the cover.
Put a Gasket on an AJ6, and it will leak.
NBB2217AC is the Gasket you need, IF its an AJ16 engine.
EAC8999 is the O/ring IF its an AJ6 engine.
The following 6 users liked this post by Grant Francis:
Doug (05-25-2024),
Greg in France (05-25-2024),
JJS- Florida (05-28-2024),
Keesh (05-25-2024),
motorcarman (05-25-2024),
and 1 others liked this post.
Grant Francis (05-25-2024)
Paul
The following 2 users liked this post by ptjs1:
Grant Francis (05-25-2024),
