Throttle cable issue
Can You turn it to full by hand at the tower? Disconnect the rods and see if there's a difference. Stick a screw driver between the rod and throttle tower disk and lift and it will pop off . It you can't get to full throttle by hand with the rods disconnected you have a problem with the tower disk or TPS. If you CAN, it is with the pedal throw, cable or the linkage or throttle blades. Should be pretty easy to isolate the problem.
Could be carpet under the pedal too. Or something under the dash is blocking the upper part of the pedal.
Doug (09-30-2020)
Received 10,872 Likes
Sometimes the throttle pedal itself actually deforms and needs to be bent back.
Also, check the nylon bushings at the throttle pedal pivot point. On my XJS one of the bushing fell out, allowing the pedal to sorta flop over a bit. This resulted in 'lost motion' ....lack of full 'pull'....when the pedal was fully depressed.
Also, the cable is adjustable right at the turntable. Maybe the cable has stretched with age and the adjustment can compensate?
Very simple fix but back breaking,
Appears that the throttle cable has come loose or stretched at the pedal.
If the wire coming from the pedal slides from the clamp that will happen.
On the throttle body that wire has a 'lug' so no adjustment there.
You need to get under the dash so you can adjust the cable tension/slack.
The fix is to loosen the tiny bolt that holds the cable.
Pull the cable to shorten any slack, then tighten the bolt.
It happened to me once.
Disconnect the cable and find out !
Sometimes the cable itself fails, most commonly if the engine is poorly grounded. If the main engine ground is weak the throttle cable become the ground. Result heat melts the inner nylon sheathing
As was suggested, a bad engine ground strap can cause a ground thru the sheath, melting it to the cable inside. Disconnect the cable end at the pedastal, and see if the pedal moves the cable inside the sheath. If not, get a new cable, and add a ground strap between the engine and chassis.
I am pretty sure that the throttle cable linkage on a LHD pre-facelift v12 is in two sections. The cable does not go all the way to the pedal, but to a linkage. From the pedal to the end of the cable there is a linkage system. You have to remove a panel (from memory) on the engine side of the bulkhead to get at this linkage.
https://parts.jaguarlandroverclassic.../brand/jaguar/
ptjs1 (10-02-2020)
The following 2 users liked this post by jal1234:
Greg in France (10-20-2020),
Xjeffs (10-19-2020)
bfsgross
07-08-2010 09:19 AM
