Is this throttle response good?
Here, current state of my project.
Drive train is done, under body all welded and coated, both axles are fully rebuilt, now tweaking some motor plumbing and off we go to body shop for paint.
Here she rumbles:
Old V12 @ 500 rpm - YouTube
Here she spins @ about half throttle:
1982 Jaguar XJS, Spring Burn Off, Part 2 - YouTube
Here she rumbles:
why is the idle set so low??
i don't really understand your question "is this throttle response good"
generally thats looked at as is the acceleration good and does it begin accelerating at soon as you press the pedal down. All you did was rev it under no load which doesn't tell you much. Its just normal more or less, not good or bad. When you rev the engine is should do something lol.
also just asking....wtf is with the randomly painted blue parts.
Received 10,951 Likes
Is this a "non factory" V12? Sounds about the same as any other to my ears. Am I missing something?
that 40lbs of rotating torque converter cant help.
Right!
and i swear if you put catalytic converters back on this car when its finished i will karate chop you in the throat.
Why?
Unless they're clogged up the cat converters won't make much difference.
Why?
So i assumed it was a real question...which it was
Also yeah the auto kills the power in these cars. Its only got 3 gears and because of that if it were setup to go fast the mpg would SUCCCCK but if you convert it to a 5 or 6 speed it gets way faster and the mpg goes up too.
the TKO 5 speeds are fastest but if you custom made a 6 speed to have gears like the 5 speed and make a steep 6th gear for cruising you could have the best of both
I keep it comfortably at 500 rpm, it powers steering well, does not die and produces about 20psi of oil pressure, so no reason to go higher, unless I want more under hood temperature and fuel consumption at traffic lights.
the cat restricts the flow of exhaust. removing them allows more air/fuel into the combustion chamber at WOT. if youve got a more suitable mixture, with less exhaust gasses being trapped in the combustion chamber, and therefore less heat, you can advance your ignition timing.
i dropped 7/10ths off of my 1/4 when i removed the cat and upped the timing on my track car... and it only had 1.
you need to post your full mod list sometime.
My mods were all cheap type, mostly related to plucking over engineered junk from under the hood:
1. air injection is gone, ports are tapped with 6mm thread and plugged with bolts. Air pump is gutted and serves as pulley for A/C.
2. Evap system is gone, charcoal can was full of earth worms anyways.
3. Idle control valve is rebuilt with Volvo thermostat bulb.
4. Fans are electric, with the use of BMW 5 series 2 speed fan, now I am working on mating 2002 XKR fans in place of original metal shroud, still have 1/4" to slim them up.
5. Self made injection harness (very easy job), all refurb. injectors from some shop in Cali (about $40 each).
6. Bosch fuel pump from F150 pickup, same size, but little bit more pressure, I got bunch of them in my stash.
7. All fuel lines are redone with nice American hoses. There is one hose section in XJS that rots out nasty.
8. Plugs are jap. NGK, wires Bosch, all vacuum lines are redone in a simpler manner, with no funky elbows and metal to rubber intermediate joints.
9. Cat. converters are gone, all 4 are gutted, yet left in place for the show. Exhaust is new, by Walker of UK.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
