Throttle setup V12
Typical V engines, such as V8's and V6's have the intake manifold and throttle assembly in the V, so it's easy to have the air fed to all cylinders. The V12 didn't lend itself to that, partly because of the decision to put the spark plugs and distributor in the V, so the AAV and balance pipe performs the same function.
It depends on the conditions, but I can say from experience in very cold weather a V12 with an AAV that is stuck closed will not start unless the throttle is opened slightly.
Greg in France (08-24-2020)
jagboi 100% right. In cold weather the V12 HE will not tickover after starting, either, unless it has some sort of extra air device. The AAV works well, but not for ever. When my car was my daily driver the AAV worked fine for nearly 10 years.
Now, I have incorporated a cabin-switched solenoid extra air valve from the Jaguar AJ6 3.6 engine, as with less use of the car, it is a better solution.
Grant Francis (08-24-2020)
Received 10,979 Likes
Just thinking about it quickly.
Is it really just a matter of blanking off what needs blanking off to 'cut' the AAV out of the system??? I've been driving more, summer, and having the extra revs for the first 4-5 min of driving isn't needed, and a bit annoying. Nothing bad, terrible by any stretch of the imagination, but unneeded. And,,,
Thanks to global warming, lol, it rarely gets that cold here. Me and the lady are thinking about a permanent move to VT or Upstate NY,,, where a little gentle coaxing of the gas peddle might be necessary,,,, but it would be a cold day in hell before I took the red ol lady out in the dead of winter on salty roads... Really, if it's not a crazy maker I could try this today. My AAV elbow is fairly new so I'm not too worried about it cracking when I pull it oft... Just the vac air thru the dizzy, but I have some open air spots thanks to removing the carbon canister...
Easy work? Or complicated?
How does one NOT lose the use of the idle control screw/bolt? In eliminating the AAV?
The theory is sound - simply stop it letting air in - you'll find out pretty quick if its busted because your idle will turn to **** and need sorting.
The second they're out with salt here the XJS is grounded for me also, that said I'll still be running it on a weekly basis / bi weekly but it won't pass the gate until at least a month after the gritters go home.
#30
I think I'd rather have it fitted to a car than over my desk on a plinth.
I think these would look real nice in black but with the top part and the fins diamond cut, then lacquer the whole thing.
I don't think I'll DIY this aspect of my motor, this is a ways down the road, got to get it back on the road first, need to get the cobwebs blown out of it after 17 years asleep. Dropping the sumps and doing oils, possibly brake pipes this weekend, cooling system next weekend.
chrisleg
11-27-2018 12:37 AM
