tonk...tonk
tonk...tonk
On deceleration I get a soft "tonk" and then on acceleration another soft "tonk". There's also a low bassy vibration. I assume bad U-joints. Any alternate diagnosis out there?
So, best way to confirm this suspicion? Also, if anyone has brand recommendations or any details I should know when ordering that would be great!
I've replaced these on my XJ6, any differences here in the XJS?
How is the transmission mount, IIRC Greg had a vibration on decel that turned out to be the trans mount.
Replacing the U joints is not difficult. When I did mine I used Corvette solid joints which are much stronger. To get them out and in I used a G clamp and a couple of appropriately sized sockets.
Received 10,982 Likes
A few ideas to add to the others:
- Exhaust fouling the cage is my favourite of all the above suggestions
- Check the radius arm bushes and fixing bolts both ends
- Check the lower inner fulcrum brackets are still tightly bolted to the diff. (A search on "dog bone" should reveal a thread on this matter)
- Check rear shock absorber fixings are tight
- Check prop shaft bolts are tight BOTH ends
- Check drive shaft bolts are tight both ends
- Check all cage to chassis bolts are tight
- If all negative, check the diff is secured to the cage tightly (requires axle to be dropped as fixings are at the cage top
