Too replace or not too replace - Ignition Parts
Received 10,906 Likes
My experience with the AJ6 is the cap and rotor tend to binary failures, and I've been stranded that way before.
So put 'em back on, then go ahead and keep replacements handy as insurance.![Icon Mrgreen](https://www.jaguarforums.com/forum/images/smilies/icon_mrgreen.gif)
**whoops: I see you're running a v12 (faked out by the 6 cylinder cap, hahaha), but the same principle applies.
YOU DO NOT need to modify the Marelli system. Porsche and Ferrari all used the same system, in fact the dual plug Porsche Dissy cap look almost identical to the V12 Jag, and none of these guys had fires.
All that is needed is to maintain the ignition system. What causes the fires in the Cats is bad spark plugs, usually in the front 4 cylinders.
That is not a genuine Marelli cap but appears to be in good condition
I already have the silicone so I might as well put it in there. I was going to cut the shaft as well but maybe its not necessary?
The Porsche dual plug, isn't going to suffer the same kind of failure because you are still going to get combustion, just not maximum efficiency combustion.
Additionally, the Ferrari is just a poor comparison. The risk of Marelli fire is from driving a XJS beyond the limits of proper maintenance. The number of XJS's that were driven well beyond proper maintenance standards, versus the number of Ferraris done so is a huge ratio.
Dave1109971 (09-29-2015)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/771x421/distributor_63585_ae5723c20734190f20f62d4943b9e968d8ec2452.jpg)
That porsche rotor is a completely different design. Those are points.
I used the silicone, though I did not cut down the shaft. It may have been a good idea to do so. Hopefully I do not run into issues. Though, it apears everyone who has used any silicone at all has not run into a fire yet. Whether that is becuaes they used the silicone or because they are more on top of the maintenance from that point on will not be known. I will definitely swap out the plugs and wires along with the cap and rotor every 20k.
Anyone looking for a replacement this seems like a good price
Ferrari 400 - Jaguar V12 Distributor cap and rotor JLM 1909 1911
Received 2,399 Likes
Hoodun:
From a generic point of view, that distributor cap and rotor look to be in fine shape. The button is clean and undamaged. No signs of excessive arcing on each tower or on the rotor.
Agree, slap 'em on.
I've read of the silicon as added insulation. I've my doubts as to it's effectiveness.
But, a whole lot of necessary arcing going on in a somewhat limited space.
Carl
Agree, slap 'em on.
Carl
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
