The top to my 1994 XJS will not go all the way down.
The top to my 1994 XJS will close with no problem; however, when I want to drive with the top down, it seems to get stuck just before it is all the way down. From that position, it will close with no problem. Can anyone help?
By the way, in my last post I was asking about caliper bolts. Can you believe I found what I needed at a business that sold only nuts and bolts. Thanks for the help.
Sherman1952
Sherman1952
The following 2 users liked this post by dborthwick:
orangeblossom (07-24-2018),
Sherman1952 (07-24-2018)
The Soft Top on my 95 does exactly the same, where the rail rubs the back of the Seat backs where as has been already said you just have to assist it down by hand
It seems to be a fairly common problem that over time you sort of learn to live with
The forward edge of my rear window hangs up on the rear seat and have to nudge it out of the way as I fold it down. I know this because at the moment, the pump is empty of fluid so I manually retract it. You should do the same so that you can feel the whole movement with your hands. Turn the bypass valves to manual at the pump/motor manifold and then retract the top by hand down to full retract. Along the way you can check every inch of the mechanism as it folds and see just why it or where it is hanging up.
Windycityx
03-23-2014 12:05 PM
TomP
04-09-2013 11:14 PM
Venture
03-13-2013 01:07 PM
jimlombardi
12-15-2012 11:12 AM
