Torquatrol fan clutch test
Old 08-12-2018, 01:26 PM
leo_denmark's Avatar
Default Torquatrol fan clutch test
Hi
is there a way to test if the mechanical fan clutch works properly ?
Should it follow the drive 100% when warm, or is some slip allowed ?
The ROM and Haynes does just tell how to remove and fit the clutch...
i see some coolant temp rise when driving slowly in high ambient temperature. Temperature indication is fine at normal and high speed, so I guess my fan clutch could be causing this.
Old 08-12-2018, 02:18 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
It shouldn't be rock hard but also not loose as if it was on a ball bearing. If it spins freely, the clutch is dead. If it doesn't spin at all, it is dead. It should spin with resistance when cold.
You can also remove it and warm with a heat gun the center (a little coil) up and then spin it. If it works, it will become very stiff. When it cools again, it should turn free'er.
Old 08-12-2018, 02:38 PM
Jagboi64's Avatar
Received 3,184 Likes on 2,101 Posts
My test is when the engine is cold and off, put a few fingers on the blade and turn the blade as hard as you can. Sort of a flick, but it's hard to describe. The blade should move about 1/3 to 1/2 of a turn. Any more and the clutch is weak.
As a further thought, is the radiator clean? Did you see the pictures a few days ago of the debris between the radiator and condensor? You can't see it until the radiator is removed, or at least the top rail is removed and the condensor and radiator can be moved apart a bit and you can look between them. The fan might be fine, but the radiator is blocked and not getting sufficient airflow.
Dirty rad pics here: https://www.jaguarforums.com/forum/x...g-warm-206092/
leo_denmark (08-12-2018)
Old 08-12-2018, 02:41 PM
Well, it doesn’t spin freely, neither cold or warm. Testing it while removed from the car as described makes sense, I was just hoping for a test with a more objective good/bad criteria
BR Leo
Old 08-12-2018, 03:20 PM
Hi Jagboi
I did not see this answer before I posted my answer to Damien’s post...
I’m sure my clutch is not as firm as you describe, so as will get me a new one to fit in the winter hibernation period. I better go OE as I have the black fan, which apparently doesn’t fit all non-OE fan clutches
My radiator is fairly new, less than 8k miles, and I have just replaced the condenser, so I know for sure there is (close to) zero debris in there. There was a bit between oil cooler and radiator, which I didn’t manage to get out while in there. That would have required bonnet to be removed, and I just decided that was not a step I wanted to make to remove 4 leaves...
Thanks !
Old 08-12-2018, 05:12 PM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
It also depends on how much the temperatures rise at low speeds. As I understand it, a little bit above "normal" is fine, so long as it doesn't keep going up and up. If it goes up and stabilizes, the cooling system is doing its job.
Someone should probably load a video of a known good clutch being tested with the flick test....
Old 08-12-2018, 11:37 PM
VancouverXJ6's Avatar
I'll do this tomorrow and make a video if I remember. My clutchfan is new I put the whole thing in bolted together in a single go last year. Overall it should spin 1/4th at cold, and barely the width of a fan blade at hot. So maybe a quater turn max stone cold and 10% at hot, though I'd have to look through my pile of parts invoices to see whether this was the heavy-duty clutch or not. There is a HD version that fits the XJS that does grip alot more and thus forces more air through, its in Kirby's book.
The following 2 users liked this post by VancouverXJ6:
leep123 (08-16-2018), Some Day, Some Day (08-13-2018)
Old 08-13-2018, 01:00 AM
Great idea, SDSD and VancouverXJ6.
Interesting with the HD version, although I suppose it's for areas with really warm weather. Denmark don't qualify for that, although we were close to 35°C this summer.
Old 08-13-2018, 02:11 AM
Thanks, VancouverXJ6. That would help. Though it could be hard to determine just how much power was behind the flick, it'll be a good reference.
Old 08-13-2018, 05:59 PM
Jagboi64's Avatar
Access is always a bit difficult, so you're not going to be able to get a tremendous amount of effort into your hand. It's a couple of fingers on the blade and a snap of the wrist. Just call me Herr Flick of the Gestapo...
And from a different angle:
Both are on a cold engine, ambient about 20C. The blade moves about 1/4 turn.
Old 08-13-2018, 11:07 PM
Mark SF's Avatar
Testing it by spinning is almost useless.
Here’s how to test it properly :
http://fanclutch.com/PicsDocs/BorgWa...ives_Only).pdf
but to sum up, you should get 800-1300 rpm at 2500 rpm clutch speed, which is about 2000 rpm engine speed, that is if the clutch is not hot enough to fully engage (happens around 200-220F), but is not totally cold either.
xjsv12 (08-16-2018)
Old 08-13-2018, 11:15 PM
Why is it almost useless?
Old 08-13-2018, 11:26 PM
Doug's Avatar
Received 10,920 Likes on 7,174 Posts
Yeah, because all of us have temp probes and digital-photo tachometers sitting in out tool boxes, right?
And how the heck are you supposed to get the required cardboard cut-out in place on a Jag V12?
The spin method is satisfactory. If nothing else, if the fan free-wheels with no resistance, you know the clutch is bad. Lacking that, if unsure, you just replace it.....which is almost certainly easier than the 21-step test procedure described.
xjsv12 (08-16-2018)
Old 08-13-2018, 11:29 PM
Doug's Avatar
It isn't almost useless.
The spin test will tell you if the clutch is clearly faulty or clearly OK. On-the-cusp results can leave us in a quandary....usually solved by simply replacing he clutch
Old 08-13-2018, 11:32 PM
Yeah, I read about half and then started to get lost.
Old 08-13-2018, 11:46 PM
Mark SF's Avatar
The situation where it is somewhere between totally dead and good as new is actually what leads to mild but chronic overheating, so common with the V12.
A digital tach is $10 on EBay.
You can can do without the temp probe and the cardboard, and most if the steps. Just start the engine, wait for the initial roar to subside, and measure rpm after a few minutes. The salient info is the 40% of shaft speed, increasing to 85% when locked up.
If you’d prefer to continue to guess, you are of course quite welcome.
Old 08-14-2018, 03:16 AM
Thanks for your replies.
I tried to flick this morning. I have it on video as well. Edit: I thought I had it on video as well...
It looked very much like what we see on VancouverXJ6's videos. Temperature was 17°C ambient and engine was cold.
Thanks Mark for your contribution. I like this more scientific approach to the testing, and I believe I have access to a tach at my job. One more task on the to-do list !
BR Leo
Old 08-15-2018, 09:55 AM
Warm flick test: the fan rotates a lot easier when warm ! No need to wait for the digi-tech I have ordered on eBay...
2 hubs exist, and as my car is a bit of a Frankenstein I’m uncertain which one I have. The engine is from an 89 XJ12.
Can you identify from this picture, or should I take it off to be sure ?
Old 08-15-2018, 10:33 AM
Daim's Avatar
Remove. Just to be sure. You don't want to buy something twice.
Measure twice, cut once...
Same applies to car parts. Check twice, buy and replace once...
leo_denmark (08-15-2018)
Old 08-15-2018, 11:04 AM
Jagboi64's Avatar
Looks like the later Series III fan clutch to me. If it needs to come out anyway, then you have a good opportunity to measure.
Fan and clutch come out as a unit, I found it easiest to loosen the shroud and lift that up with the fan until the fan and clutch can be removed. Be very careful that the lower tips of the blades don't damage the radiator. You may not want to buy from them for shipping cost reasons, but Rockauto.com is good for listings and dimensions. The 89 XJS is the same part as the XJ12. An example: https://www.rockauto.com/en/moreinfo...178793&jsn=479
Quick Reply: Torquatrol fan clutch test
