Torque settings for oil pan bolts?
Received 10,876 Likes
Jagxjs (12-24-2012)
Are you sure that the oil is leaking from the sump (pan) and not dripping down or being thrown from somewhere else and just appearing to come from there?
There must be a reason why the bolts are slack (if they are).
If you have oil leaking out of the sump then the bolts can only be finger tight.
Put a spanner (wrench?) on them and see how much slack that you can take up; if it is more than a quarter of turn (without putting any force on it) then whomever replaced the sump didn't tighten them up properly.
Then you have to ask. Why?
The sump is a non-load bearing or pressurized item so there probably is not a definitive torque setting: it just has to be tight enough to compress the gasket sufficiently to prevent hot oil leaking out.
Hand tighten all the bolts, clean everything that you can reach and then take the car out for a good run (i.e. cane the **** off it whilst watching the gauges).
Jack it back up and see exactly where the oil is coming from.
And don't forget the sump plug (should have mentioned the first); the threads can wear and pass oil.
There are 3 lengths . There is some small , one medium, and some long. The medium one picks the oil pipe bracket up. The rest speak for themselves when you look at it or try one in. The longest ones go along where it meets the torque converter and the adjacent edge. If you put a small one in and it doesn’t pick any threads up, you need one of the long ones. Hope that helps , I’ve just took my sump off. V12
Wes Steenrod
09-06-2015 06:52 PM
philwarner
09-05-2015 10:05 AM
