towing hooks
Received 10,872 Likes
All the Jags I've owned have front tow hooks attached to the big bolts at the front of the subframe. #15 in this illustration
http://www.jaguarclassicparts.com/uk...ember-assembly
Cars with the inboard brake IRS have a strap on the lower control arm that works well as a recovery hook. Item #27 in this illustration
Wishbones and Mounting-Rear - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK
Those front hooks or loops are to tie it down... Not to two it, as they sit higher than the front chin spoiler. Resulting in the rope damaging the spoiler.
I have always tried to find a place to attach a rope and will probably have one welded behind the lower radiator grill. I mean, that grill can be removed within minutes. Modern cars need you to search for the hook in the boot, then pry a cap off, etc.
caterwaller,
You haven't mentioned which model, but the late facelift big-bumper cars have a towing eye on the right front side. This is an eye welded to the front box section of the bodyshell.
I'm not sure how it might exit with the bumper configuration of a pre-facelift but it might be possible to cut one off a facelift and weld in the same place on a pre-facelift.
Paul
Paul
If it's just a matter of an "easy pull" like winching a free-rolling car onto a flatbed tow truck or trailer you can just use a lower control arm....if your cable or rope doesn't foul the spoilers or sheet metal
Or use the hooks previously mentioned but with a block of wood to prevent the cable from fouling the body
For a harder pull you can run your cable around the front subframe...perhaps directly below the engine
JLBolen (10-22-2016)
Like Doug said, If it is a easy pull, car has tires and wheels on it with air in them, not in a ditch or other accidental areas. (I used to manage a wrecker company outside of Washington D.C. so I am familiar with towing cars.) The company I use, has a Tilt and roll back flatbed truck. They just hauled a 83 XJS home for me. They used straps around the lower control arms at frame end, blocked that down with a 4x4 to keep straps from touching the spoiler with a ****** block at the rear end of the bed to keep cable down low. After car was angled up on the bed, they removed ****** block and pulled car up until rear wheels were on bed, lowered bed and finished pulling car forward. Then the used special wheel straps to secure the car to bed on all four corners. Unloading was easy, they lowered bed and let car roll back with winch until rear wheels were on ground, unhooked cable and finished letting car roll off. No damage to any part of car, under carriage or body. Using a trailer should work about the same. Most wrecker services will have proper equipment to move a car safely without damage. Just let them know what type of car is to be moved. Damage would be most likely from using J hook chains and a Sling type wrecker. Trailer, Tilt and roll back or Cradle Snatcher type wrecker would be best.
catterwaller (10-24-2016)
