Towwing an XJS on a dolly
Towing an XJS on a dolly
Anyone here used a U-Haul car tow dolly to tow an XJS (backwards)? Is there enough ground clearance remaining, so the front of the car doesn't scrape?
EDIT: Sorry for the misspelled title. Won't let me edit it....
Not sure how much of an angle you will be on. There is not muxh clearence at the lower spoiler.
I would NOT tow it any other way than backwards, if that clearence works out.
To tow it it front up, the prop shaft would need to be removed. Maybe only at the diff end and tied securely out of the way of the pinion flange.
My $0.02, I would get a flatbed like Jagfixer mentioned. I towed a car recently that ended up not fitting on a two wheel dolly and I found that the flatbed was only $20 more per day or something of the sort. If I had known that when I first rented the two wheeler, I would have gotten the auto transport (full trailer) anyway. It's worth it for the piece of mind you get knowing that you're not scraping off anything attached to your Jag, and you can more securely fasten it to the trailer to boot.
I would never tow an XJS on a dolly.
These cars sit very low and the front spoiler is only a few inches from the road. If you put the rear of the car on a dolly the spoiler would have almost no clearance. One good bump and the spoiler would be gone.
You also cannot tow the XJS from the front because like most cars with automatic transmissions, the transmission will be damaged. As stated above, you would need to disconnect the drive shaft if you wanted to tow the car with the rear wheels on the road.
The only way to go is with a flat-bed truck or trailer.
Mark
Mark
