tps checking
tps checking
my car is a bit smelly on idle running rich, thought I would check the tps but after connecting a volt meter across the yellow and red I cant get any volt reading at all from across them with the ignition on in any throttle position, only full ohms which goes down and back up again when turning the capstan, what am I doing wrong please
its only a 2 wire volt meter, is it the wrong sort as I cant see why it would work if it isn't earthed.
The following 2 users liked this post by JayJagJay:
Grant Francis (09-05-2019),
rgp (09-05-2019)
got the digital multi meter and its well out at a reading of 1.9 so could be my problem, thanks for your help and advice,
I have had it off the car a couple of times in the past but because the plastic showed signs of where the washers pressed into it I just lined those up, obviously not a good idea
The following 2 users liked this post by rgp:
JayJagJay (09-05-2019)
rgp (09-05-2019)
