Transmission leak
Old 03-28-2016 | 11:44 AM
JayCee's Avatar
Mac...
Finally managed to get the hoses off. Had to completely remove the air cleaner box to get to the other end. Then they came off the rack easily, but still took 2 hours. What I'm worried about now is the fact that I wasn't able to determine where the leak was coming from. The top of the tower and around the seal looked dry, so that's a good sign.
The new hoses should be here in a few days, which will give my back and neck time to recuperate a little. Also, the scrapes and cuts on the arms and hands.
Later...Jimmy
Mac Allan (03-28-2016)
Old 03-28-2016 | 01:13 PM
Mac Allan's Avatar
Well done.
Sorry I forgot about telling you to remove the air box. It sounds from your description it is very likely the leak is in the high pressure hose.
Old 04-06-2016 | 09:06 PM
JayCee's Avatar
Well...finally done. Drove the car a couple times and no more leaks.(at least not from the steering!) Not a fun job!
Mac thanks for your guidance with this job...not sure I would have tried it without reading about your ordeal first.
Now to get a big cookie sheet under that oil pan.
Thanks...Jimmy
Mac Allan (04-06-2016)
Old 04-06-2016 | 09:17 PM
Mac Allan's Avatar
Nice work.
No, it's not necessarily a "fun" job, but when the light at the end of the tunnel doesn't turn out to be a oncoming train, there is a certain satisfaction to it.
Congratulations! I'll toast you tonight with a good single malt.
ericjansen
09-25-2019 07:10 PM
reichstall
03-14-2016 07:43 PM
Britrover
03-10-2016 10:49 PM
redtriangle
03-07-2016 07:08 AM
r__h
03-05-2016 03:12 PM
Quick Reply: Transmission leak
