Transmission Mount
I have a 1995 XJS 4.0 Automatic Convertible..
How do I tell if the transmission mount is bad? I have a drive line vibe at 60-70+ that is worse while coasting than under load. When under the car the transmission moves up and down rather freely with very little effort.. I have looked and noticed that there are multiple parts/pieces to the transmission mount, how stiff is it supposed to be?
xjsPaul
Received 10,938 Likes
I'm not familiar with the specific arrnagment on your car but experience with trans mounts on other Jags is:
- they are all needlessly complex :-)
- they all have more movement than an typical rubber block type of mount
- they are made from soft materials for noise/vibration insulation
- they are sometimes weak/too soft even if they don't appear broken
- when in doubt, replace!
I'd say about 1" of easy movment is typical.
Besides the u-joints already mentioned also check the driveshaft bearing....if your model has one. I'm not sure if it does. It's what secures and isolates the driveshaft from the body of the car. If you have one it'll probably be more towards the rear of the driveshaft.
Now for the correct You Tube Segments
YouTube - Wheeler Dealers - Jaguar XJS - 1/4
4 segments, one covers the trans mount change out.
XJSPaul
XJSPaul
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
02-11-2016 06:03 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
