Transmission Oil Cooler Lines Removal
Does the exhaust have to be dropped/removed in order to remove both trans oil cooler lines? One of them are leaking but I wish to replace both. There is a hydraulic hose place where I live that can make something as from what I understand these lines are hard to find. (saw some used ones on fleabay for $130.00)
V12 or I6?
In case of the V12, the pipes (!) run along the side of the block. The are screwed directly into the transmission. There is no rubber along there. The only rubber is between the front end and the radiator.
So of you just want to rubbers replaced, you don't need to remove the block lines. If you want the block lines removed, then it would be easier to remove the exhaust manifolds BUT that can turn into a PITA. Might be easier to hack them off at the tranny end and replace them with some full rubber ones then...
orangeblossom (09-29-2017)
would help if you put in the year and engine you have. as far as the tranny cooling lines, when I changed mine, the exhaust manifold did not have to come that is if you're only replacing the rubber portion. but for easy access you will have to remove the front spoiler and even better access some of the other parts under the front. I did have to buy completed lines already made for mine but had to cut and split the coupler at the cooler end due to it was corroded on.
When I had the TH400 in my 91 one of the first things I did was get rid of the rad trans cooler. I cut off the two cooler lines at the trans removed the fitting, welded on 1/2 pipe threads & ran -6 AN fitting & ss braided line to a alum. tubular heat sink type cooler mounted below the front bumper. I had a temp gauge but can't remember the degree diff but did run cooler.
