Transmission problem
Hello
I was driven my 1996 Jaguar xjs 4.0 normally when I stop on a red light and going on a green light a minute after the transmission had neutralize now the car start normally but the transmission not working on any gear.
Other question.. A 1994 jaguar xjs 4.0 convertible frame will fit to a 1996 xjs 4.0?
Thanks.
Thanks.
Hello
Thanks.
Thanks.
Hello Carsnplanes
I checked the transmission fluid level when the engine was cold, the stick fluid level check has 2 lines the lower line when the engine is cold and the upper when is warm, I checked and the transmission fluid was above the upper line it has to much fluid.
