Transmission question
Old 02-28-2010 | 02:07 PM
jeepguy's Avatar
Default Transmission question
We have just got my 1983 XJS running. We took it out for a ride and it didn't shift until 4000 rpm's. It seemed fairly high but I have no experience with theses cars. So my question is, what is the normal rpm’s for it to shift at? Thanks.
Old 02-28-2010 | 05:54 PM
Doug's Avatar
Not normal...unless you are using a lot of throttle.
You have a faulty vacuum modulator or the vacuum hose to the module is broken/disconnected.
Old 02-28-2010 | 06:11 PM
S.E.R.E.'s Avatar
depending on how your driving determines the shift point. just tooling around town i shift around 2000
Old 03-01-2010 | 06:03 PM
jeepguy's Avatar
Where is the hose located? The engine has acts like it has a vacume leak so there is a good chance that may be the problem.
Thanks.
Old 03-01-2010 | 10:50 PM
Doug's Avatar
Thanks.
Near the rear of the right side cylinder head or cam cover.....my memory won't generate anything more specific than that, sorry.
Might be easier to trace it upwards from the trans.
The vacuum modulator is on the right side of the trans...a small cannister type of device. You'll see it
tomsjag
06-10-2023 10:02 AM
Jandreu
06-30-2022 03:10 PM
aholbro1
08-05-2021 05:02 AM
ahunt4
09-14-2015 08:17 PM
AtholC
09-09-2015 09:07 PM
Quick Reply: Transmission question
