Transmission Removal procedure?
I have my engine and gearbox out of the car at the moment. I would like to fully drain and change the oil but not sure how to go about this. Could anyone tell me the best method and if there is any other preventative work like seals etc I should do on the gearbox while I have good access? Many thanks in advance
JAGUAR DAIMLER GM400 GEARBOX FILTER KIT XJ12 SER 2 & 3 XJS DS420 AAU6690 JLM1487
The standard cork filter is not a brilliant item, and dressing it with gasket goo sparingly each side will help as long as the surfaces are 100% clean and oil free, but do NOT do it up too tight, just a touch more than finger tight.
Deep pan aftermarket sumps with drain plugs are available, as are better gaskets, the Rolls Royce of which are Moroso items 9with RR prices) eg:
https://www.summitracing.com/int/sea...pan-style/deep
https://www.summitracing.com/int/par...2020/overview/
Greg
I removed my BW65 and left the kickdown cable attached to the transmission. I disconnected it at the other end, where it attaches to the throttle spindle on my car. Then I delivered it like that to the guy who rebuilt the trans. I reinstalled it with the cable attached to the transmission, snaking the cable back up the engine. Are you not able to remove it at the other end and pull the transmission with it attached?
#30
#31
#32
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20200705_101736_e33bda31d80089a9702559ff71f848d7393d1565.jpg)
9 all together. 8 then the 12 point one.
I've been reading and such and I think its just stuck on the dowels.I finally found where the dowels are located and i guess they do stick and some heat usually gets them free.
#33
#35
One hour? Incredible. Was it difficult to lower the engine in order to access bellhousing bolts?
aholbro1
08-05-2021 05:02 AM
