transmission swap on a 96 6cyl 4.0.l
I think my current transmission is the ZF4HP24E (correct?)... it has about 170k miles and it stopped shifting about a year ago... I was wondering if the GM 4L80E would be a straight bolt on swap?
which one is more reliable?
would I be better off rebuilding my current one or buying a rebuilt 4L80-E?
what other things to consider?
Get the ZF rebuilt. They are good transmissions.
I'm not even sure the 4L80E would bolt up. It was used behind the supercharged 4.0 but I *think* those blocks had a different bolt pattern or an adpater plate was used.
Next is the electronic compatability between the 4L80E and your car's electrical architecture. Could be a big problem.
Lastly, even if you could make it work, the 4L80E is heavier and sucks off more power than the ZF.
aholbro1
08-05-2021 05:02 AM
40, 4l80e, 96, bolts, conversion, cyl, electronic, jag, jaguar, rebuilt, swap, transmission, xjr, xjs, zf4hp24e
