Trembling noise
Old 01-10-2015, 03:55 AM
yabaman's Avatar
Angry Trembling noise
Hi Guys
I have a 1990 Jaguar XJS 3.6 coupe and i can hear a trembling noise when accelerating hard from stand still only. It seems that the tremble is coming from the transmission area as if the whole unit is shaking on acceleration.I had the mounts changed but still the same problem. I cannot pinpoint the where that noise is coming from and neither could the mechanic say for sure. Anybody out there had a similar problem?
Old 01-10-2015, 04:06 AM
GGG is offline
Received 16,861 Likes on 12,186 Posts
Welcome to the forum yabaman,
I've moved your question from Europe Region to XJS forum.
This is the place to post tech questions about your XJS and members here with the same model will be able to help.
yabaman (01-11-2015)
Old 01-10-2015, 04:09 AM
yabaman's Avatar
Thank you very much. Ill soon get the hang of it
Old 01-10-2015, 05:23 AM
superchargedtr6's Avatar
My first thought is a bad u-joint. Next would be the tail shaft bearing. I would think a very bad transmission fluid leak would accompany a bad tail shaft bushing though.
yabaman (01-10-2015)
Old 01-10-2015, 06:00 AM
Greg in France's Avatar
Received 9,323 Likes on 5,472 Posts
The 3.6 has a bearing fixed to the floorpan halfway down the propshaft, effectively a two-piece propshaft. If this is worn out it would produce these symptoms.
Link
Propshaft-3.6 Litre-Automatic - Parts For XJS from (V)139052 to (V)179736 | Jaguar Heritage Parts UK
Greg
The following 4 users liked this post by Greg in France:
Japthug (01-10-2015), orangeblossom (01-10-2015), superchargedtr6 (01-10-2015), yabaman (01-10-2015)
Old 01-10-2015, 07:23 AM
yabaman's Avatar
Thank you for the helpful info
Old 01-10-2015, 09:01 PM
That could most likely be it! I responded from ignorance of the 3.6. I've only delt with V12 XJSs, and had no idea any XJS had a center bearing.
Old 02-19-2015, 05:58 AM
yabaman's Avatar
YESSSSSS it was that special bearing that caused that rumbling noise on hard accelaration.It took some time to find cause the part num was superseded.
I just want to thank Supercharged and Greg for his detailed diagram and valuable help guys. Thank you
The following 2 users liked this post by yabaman:
Greg in France (02-19-2015), Gunner01 (02-21-2015)
Old 02-19-2015, 09:53 AM
Just FYI, and in case you do not know, there is a water hose under the inlet manifold that is slightly S shaped and about 8 inches long, connecting the water pump to the block.. Nobody knows it is there. If you have never changed it, do so now, as it fails spectacularly and all the water gets pumped out in about 15 seconds.
The following 3 users liked this post by Greg in France:
Gunner01 (02-21-2015), orangeblossom (02-20-2015), yabaman (02-20-2015)
Old 02-20-2015, 07:43 AM
yabaman's Avatar
Thank you Greg.I will find the part number and order it just to be on the safe side cause i really dont think its ever been changed.cheers :0
Old 02-20-2015, 11:00 AM
Part number 3 on the diagram. Do not delay...
Greg
The following 2 users liked this post by Greg in France:
orangeblossom (02-20-2015), yabaman (02-21-2015)
Old 02-21-2015, 12:15 PM
Gunner01's Avatar
Not that Greg in France needs my backup, but yes this was the cause of my first XJS roadside let down with the recently purchased car
Although, it was a very impressive smoke show
Old 02-21-2015, 01:17 PM
yabaman's Avatar
OMG....im not gona move it from the garage till I change ALL the hose pipes lol ....
JimC64
31
05-30-2016 03:04 PM
inactualis
10-02-2015 11:13 AM
baskervillema
10-01-2015 06:43 PM
ChrisJay
09-27-2015 09:08 AM
UKnFor-dluv-expat
09-26-2015 08:40 PM
Quick Reply: Trembling noise
